587,997 active members*
1,647 visitors online*
Results 1 to 10 of 10
    Mar 2007
    19
    Software ideas needed....
    I am new to this forum. I have been lerking for a couple of weeks now and just signed up today. I can't seem to find what I am needing help with. I am new to the cnc world. I am the only programmer my company has. We have 2 mills and 3 lathes. The newest is a QT200 640T fusion. We only have several hundred hours on it.
    I am looking for some software that will allow me to program from my desk and create layouts/setup sheets per program. Our goal is to network all of these machines to one pc. We use a generic setup sheet now that is lacking to say the least. I have been designing and making tools for years. I use auto/cad and Bobcad/cam now. Mostly for wire EDM work. We have several hundred programs on file that need to be on setup sheets. Problem is that we run the same jobs on 3 different machines that require 3 different setup sheets. Our mills are mostly used for second operation. All of are lathes are just 2 axis machining. Any help or sugestions on software would be great. Nothing that we have will even read the files coming off the Mazaks.
    Mar 2004
    761
    Hi Txshane,
    Welcome to the forum.
    First question:
    Are you running Mazatrol and / or G-Code on the QT200 640T Fusion control?
    It makes a big difference on the software you will need to load and save your programs with.
    Wayne Hill
    Mar 2007
    19
    I use both. I don't use g-code unless I have to.
    Oct 2006
    586
    I have 4 lathes and 4 mills what i do is put the set up at the head of the program that way you can have a print out of it and it is in the machine as well it works very well for us if you have 2 different machines just make side notes in the setups, as for linking them you need a good comunication software with the amount of machines you have you can use i com. and get a switch box and just set all your baud rates the same, now if you want to spend the money you can get wireless coms. witch i think is a better way to go i havent forked out the money yet but i plan to "i use Multi DNC for my comunications i like it it has back plot, time est., calculator there are several to choice from
    individual who perceives a solution and is willing to take command. Very often, that individual is crazy.
    Feb 2007
    664
    from what I'm understanding is that you want to be able to post tapes for all machines at once
    and have a setup sheet for each machine as well
    so an operator can call up a part number and receive the proper tape and setup sheet for the machine being run
    is this correct
    Feb 2007
    664
    do these machines have network capabilities
    Mar 2007
    19
    I just purchased Camlink for the bargain price of five arms and six legs. Any input from current users would be great.
    Mar 2004
    761
    Camlink can do the file transfers. We use it all the time.
    It costs us six arms and legs. You got a good deal on it
    Connect it to a standard PC serial port. Do not try to use a USB Serial add-on box with it.
    Wayne Hill
    Mar 2006
    42
    Feature cam post well and supplys all the neccesary paperwork i have camlink and Featurecam and use the cam
    May 2013
    This is interesting to see what you are going thru. Since 2007, I would love to hear how you are doing, if you are still at this company, etc. We have setup sheets for a few Mazaks but create setup sheets seperate from the CNC's
  1. Build Ideas needed
    By Drools in forum DIY CNC Router Table Machines
    Last Post: 08-29-2009, 04:52 AM
  2. Ideas for software
    By saarela in forum Uncategorised CAM Discussion
    Last Post: 09-04-2008, 12:22 PM
  3. Looking for ideas for a small mill DXF files needed
    By Fixittt in forum Benchtop Machines
    Last Post: 08-21-2007, 06:21 PM
  4. ideas needed
    By absjalray in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 06-03-2007, 01:59 AM
  5. ideas needed
    By absjalray in forum Community Club House
