588,515 active members*
5,216 visitors online*
Thread: A cnc clock
Page 3 of 4 1234
Results 41 to 60 of 70
  1. #41
    6855
    Originally posted by FourStroke
    Hey Paul
    I'm glad you sold me the cnc router table>I'm finding a lot of interesting stuff on this site to try it out on.
    Frank
    Ref::
    CNCadmin
    Administrator/Owner
    Now I wish I did'nt sell my CNC router table.
    __________________
    Thanks,
    Paul G
    Site Webmaster, Administrator
    & Proprieter
    I'd still rather be flying!
    Glad it's working out, keep us updated I want to see what your cutting with it.
  2. #42
    Jul 2003
    168
    balsaman,
    It'll be a year next month that you finished your clock.
    How well does it keep time?
    How well has it help up?
    Is the MDF dry yet?
    Dan
  3. #43
    2139
    Well,
    The MDF "pawl" which is the ratchet mechanism that allows the clock to be wound up lost it's spring tension and was allowing the weight to suddenly drop to the floor. In the interest of safety I took it down untill I could cut a new pawl from a more suitable material (maybe quality plywood). I havent cut one yet, so it was only in operation for a couple months.
    I had plans to cut another complete clock from hardwood or plywood but that hasn't happened either....maybe I should spend less time posting and more time "doing".
    Sorry I can't give you a better answer.
    E
    I wish it wouldn't crash.
  4. #44
    Jul 2003
    200
    Hello,
    But DURING that two months, how well did it keep time?
    Thank you in advance,
    Ballendo
    Originally posted by balsaman
    Well,
    E
  5. #45
    May 2003
    267
    Are there CAD files that come with these clocks and how much of the parts can be machined using the CAD files? How much for the complete plans and cad files? Are there any advantages to making them out of aluminum?
    Thanks,
  6. #46
    Dec 2003
    259
    Balsaman,
    What size are the large gears with the curved spokes?
    and what size cutter do you do the teeth with to get into the root of the tooth ?
    Very nice work BTW, I'm pleased to see you recycling scraps of expensive MDF, that stuff doesn't grow on trees.
    John S.
  7. #47
    2139
    The bigger gears are ~6" diameter. All cut from the free cad files with a 1/8" carbide endmill. The face numerals used a 1/16" endmill.
    E
  8. #48
    Jul 2003
    200
    Balsaman,
    Maybe you missed my message above...
    How well did the clock keep time during the month or so it was hanging?
    Ballendo
    P.S. What did you use for the shafts? Dowel? Any special species or?
    E
  9. #49
    2139
    It kept time within a few minutes per 8 hours. It needed to be wound every 8 hours, so it rarely got wound, unless someone wanted to see that it really worked. It was more of a display piece (an MDF one at that..). Since it rarely was wound, I never spent any time playing with the length of the pendulum, which is what adjusts it's speed, so to speak.
    The shafts were just 1/4" dowel from the hardware store. If I did it again (I will), I will use brass rod for shafts, and probably brass sleeves as well where sleeves are used. I used clear plastic tubing for sleeves on this one. The sleeves allow several gears to run independantly on one shaft.
    E
  10. #50
    Jul 2003
    200
    Thank you for the reply!
    What type of plastic?
    Ballendo
    E
  11. #51
    Feb 2004
    Cut Gears from AutoCad
    I' desing my own Clock from AutoCad. Would you main tell me about differents possibilities to cut gear in metal or wood.
    I would need to be able to have a cheap solution. It's possible.
    What kind of brad and model advises me ?
  12. #52
    2139
    It was a hard clear plastic tubing used for a sightglass for checking the fluid level of a tank. It was about 9/32" ID. Sorry, I have no other info.
    If you go to a hobby store, you can find brass tubing in ID's going up in 1/32" increments for a few dollars for 12" lenghts. That is what I will use on my next clock.
    jzyfcy,
    I am not sure I understand your question. It's going to be easier and cheaper to cut one from wood.
    E
  13. #53
    May 2003
    267
    Where can I download the cad files to make these clocks?
  14. #54
    May 2003
    267
    I am interested in milling this clock as my first CNC project. I just downloaded the DXF files. However, the dxf files are all 2D graphs. How do you convert the 2D drawings into 3D models (e.g. extrude)? I am using Solidworks and PowerMill or VisualMill. Can someone show me how this can be done?
  15. #55
    Apr 2003
    1873
    Georgebarr these do not need to be 3D to machine, unless you wanted to just view the parts in 3D. Unfortunately every drawing program has it’s own set of guidelines to modeling of which extruding is one of them, in my software either the entity must be a solid or surface to extrude. Every part has it’s own unique requirements and method to convert to a solid as well.
    Ken
  16. #56
    2139
    I just used the 2D drawings, and cut them from flat stock.
    Eric
  17. #57
    Apr 2003
    1873
    balsama, impressive piece of work.
    Where did you locate the roman numeral font? , been looking all over and cannot find them.
    Ken
  18. #58
    Jun 2003
    67
    How did you hold the material on the cutting surface? Spray adhesive? I may have missed it in the read through. If you used the adhesive, how did you get it off? I commonly user 3m sprays on aluminum and carbon sheet, and clean it with laquer. Seems like that wouldn't be good on ply or MDF. Thanks.
  19. #59
    2139
    I think I just drew the roman numerals by hand. I held the material with bolts. The gears "came loose" when finishing the cut. The littlest gears were "drilled" for the shaft first, bolted thru the shaft hole, then the outside was cut.
  20. #60
    Oct 2007
    Recently I was checking out some software samples and saw an octogon clock face with roman numerals and can not remember where this was. Would like to try it in my CNC mill. Any help is appreciated.
Page 3 of 4 1234
  1. Using your CNC Mill as a CNC Lathe
    By lstool in forum Knee Vertical Mills
    Last Post: 06-12-2017, 02:29 PM
  2. Making money with CNC
    By Johnuk in forum Community Club House
    Last Post: 12-13-2009, 05:46 PM
  3. Beginners CNC Advice
    By UKRobotics in forum Uncategorised MetalWorking Machines
    Last Post: 10-08-2009, 05:10 PM
  4. Newbie to CNC world
    By HighOctane in forum DIY CNC Router Table Machines
    Last Post: 01-25-2005, 08:58 PM
  5. The start of a big CNC project...
    Last Post: 09-30-2004, 11:34 PM
