587,743 active members*
3,060 visitors online*
Results 41 to 43 of 43
Threaded View
    Oct 2004
    198
    Talking How to correctly chamfer a hole?
    I'm attempting to chamfer a hole in a cylindrical shaft, obviously very easy to do, that only reason I'm having a problem is that I'm trying to chamfer the correct distance all the way around the hole, rather than using a 90° tool and plunging straight down.
    You can see from the pic what I mean, the smaller hole is what you normally achieve (the chamfer changes size on the way around the hole) but I'm trying to achieve much the same as the larger hole.
    I'm trying to achieve this without cad/cam, is there a way to calculate this using a spreadsheet?
    Thanks.
  1. Chamfer hole located on an angled
    By colby2000 in forum CNC Swiss Screw Machines
    Last Post: 04-17-2014, 08:34 PM
  2. Cross Hole Chamfer (G16? G12.1?)
    By Ovrclck350 in forum CNC Swiss Screw Machines
    Last Post: 02-14-2014, 04:32 PM
  3. tapped hole chamfer with iscar chamfer tools
    By dcutler35 in forum Mastercam
    Last Post: 12-07-2012, 02:30 PM
  4. CHAMFER FOR TAPPED HOLE
    Last Post: 07-03-2012, 09:11 PM
  5. Depth Calculator - Chamfer a hole
    By jcnewbie in forum Mastercam
    Last Post: 10-23-2009, 11:55 PM
