587,997 active members*
1,843 visitors online*
    Mar 2007
    34
    deep grooving
    Im having good luck pecking my partoff tool, feeding down .100, then retracting .005, feeding down another .100, and so on. Right now, Im typing it in at the machine.There has to be a G-code for this, Deep drilling in X instead of Z,? or, deep grooving. Like: G?? X-.032 D1000 U.005 R0 F.003:??? help please.(Fanuc control, Hwacheon lathe) I only want to retract .005 to break the chip, I dont want to retract all the way out of the part. Any help would be greatly appreciated.
    May 2003
    try using your drill peck cycle for mori seiki its g74 x is depth k for amt of peck
    r for back off
    x1.25 y1. position move
    g74 x1.2k.100r.05 f.005 canned groove cycle
    May 2007
    1003
    On machines in my shop a G74 is for drilling or face grooving. G75 is the cycle for o.d. grooving, c-o, live tool radial drilling, etc.
    There are 2 different formats depending on age of machine. Newer ons all use a 2-block format.
    G75R.005
    G75X-.02Z(OPTIONAL)P1000F.0025
    R-value is the retract amount. P-value is the DOC before retracting. Example would peck .1 deep before retracting .005. Making P-value smaller increases cycle time, but breaks chips up better if they are causing a problem. On some internal grooves, I've made the peck depth less than the feedrate for maximum chip breaking.
    Older machines use a 1-block call. It has been a while since I programmed one of them so I won't give an example for fear it might not be right. It is similar to your example. I will give you the exact format Tuesday when I get back to work. HTH
    Mar 2007
    34
    G75 X0 I500 F.002:
    Works, retract for G74 and G75 are set with the same parameter.
  1. What is the G code for Grooving? Not G75?
    By cjchands in forum Mach Software (ArtSoft software)
    Last Post: 04-22-2007, 11:07 PM
  2. acme with grooving tool 2d or 3d?? help
    By jone in forum Mastercam
    Last Post: 04-16-2007, 12:41 AM
  3. Fanuc G75 Grooving Cycle post processor
    By rk176 in forum FeatureCAM CAD/CAM
    Last Post: 11-07-2006, 02:00 PM
  4. .250 Dia x 22.00 deep ??
    By Rekd in forum DNC Problems and Solutions
    Last Post: 02-25-2005, 03:24 PM
  5. Cutoff/grooving problems
    By july_favre in forum Mini Lathe
    Last Post: 07-30-2004, 06:42 AM
