588,550 active members*
4,954 visitors online*
Page 3 of 10 12345
Results 41 to 60 of 192
  1. #41
    May 2004
    105
    What precision level are those bearings rated at? I'm just curious as to what sort of accuracy you are shooting for.
    -John
    http://www.engineeringhobbyist.com
  2. #42
    Quote Originally Posted by JH-Q View Post
    Any ideas what kind of cover i need to prevent coolant from getting to spindle bearings and still allowing rotation?
    I think that a "labyrint" (as it is called in the Netherlands) will do just that..
    if you have a "collar on the spindle, any coolant will be swept off, when you put a ring around it, any fluid will just flow to the bottom, and back into the machine
  3. #43
    nice job so far. im interested in how you make your spindle, especially how you keep it oriented properly in relation to the axes.
  4. #44
    Jun 2003
    3312
    Wow!
    Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
    Vist my websites - http://pminmo.com & http://millpcbs.com
  5. #45
    Oct 2005
    162
    Any Progress??
    On the other hand, You have different fingers.
  6. #46
    Yes, i have done a bit of work on it. The spindle is now almost ready and the main frame for the lathe will be welded this week. Also i ordered a ballscrew for Z-axis, it is 31mm in diameter, got 5mm pitch and is 600mm long.
  7. #47
    Sep 2005
    249
    Beautiful! I love your lathe!
  8. #48
    The frame is now welded and looks really good!
    The welding was done by my former classmate, who is a talented welder. I asked him to do it as my welds aren't that good.
  9. #49
    Aug 2005
    96
    Fantastic job!
    JH-Q,
    Impressive job you have done there!
    I'll be watching this thread!
    Regards
    Sandi
  10. #50
    Z-axis ballscrew is here!
    Diameter: 31mm
    Pitch: 5mm
    Lenght: 600mm
    Cost: ~120€ including shipping and customs (85$ buy-it-now bargain)
    The screw looks precicion ground and moves incredibly smoothly. Also i didn't notice any backslash on the ballnut.
  11. #51
    Aug 2005
    96
    Ball Screw
    JH-Q,
    Where did you order that ball screw from? ebay?
    Regards
    Sandi
  12. #52
    Jul 2005
    969
    nice ballscrew
  13. #53
    Oct 2006
    49
    wow i am now going to be fallowing u as well
  14. #54
    Jul 2003
    586
    So did you mention what the spec on the spindle bearings was? And ...o..yea... great job!!!
  15. #55
    Jan 2006
    481
    Quote Originally Posted by sposl View Post
    JH-Q,
    Regards
    Sandi
    HI JH-Q , i second that question , " Where did you order that ball screw from? "
    do you have a website that has a direct link to the supplier ?
    nice work JH-Q , very impressive , the way the CNC_lathe is progressing , you will just up the workmanship stand by 1000% , makes it very hard for us old timers
    cheers
  16. #56
    The ballscrew was bought from ebay, i waited almost half a year waiting for suitable one come up for sale.
    Spindle bearings are some chinese brand, but they claim to handle 4300rpm with grease and 5000+ with oil lubrication. I'm going to set the mechanical max. spindle speed to 3200-3300rpm and electronically limit it to 3000rpm. I didn't find any accuracy datasheets but i hope they are accurate enough.
    The frame is now machined, i still have to do some burr removal and tapping on it, and then i will post some pics of it
  17. #57
    Feb 2007
    24
    Best low budget cnc-projekt I have seen!
    Everyday I´m looking if there is somthing new.
  18. #58
    Here is the updated cad-drawing.
    The movements are now decided, X axis will be around 75mm (150mm in diameter) and Z around 300mm.
  19. #59
    Mar 2004
    1306
    Great project.
    Have you encorporated the coolant system, and coolant/swarf drain flows into the design?
    Do'nt forget the enclosure design. I found that the enclosure was one of the biggest advantages of CNC'ing my listtle lathe at home.
    Regards,
    Mark
  20. #60
    Mar 2004
    1306
    Do you have an estimate of what it will end up weighing? Looks like a lot of steel
    Regards,
    Mark
Page 3 of 10 12345
