Couple of comments: If the hydrocal is alkaline it will actually tend to reduce corrosion; acid promotes corrosion in steel alkaline recduces it.
ckelloug; in a couple of places in different post you mention pre or post tensioning reducing deflection...are you sure? Deflection depends entirely on Young's modulus, are you modifying the modulus with the tensioning? I thought that all tensioning did was increase yield strength by putting tensile stresses into the tensioning medium instead of relying on the tensile strength of the bulk material.
