588,350 active members*
5,772 visitors online*
IndustryArena Forum > CAM Software > PTC Pro/Manufacture > post for mazak 640 m Nexus
    Jan 2007
    3
    I created a big part of my post with the Option File Generator but I have problems with the tool change and the drill cycle.
    I am not able to place the next tool on the same line of command ( ex: T01 T02 M06)
    And I have to add the G83 (or 84 or 86...) by myself in mt text file.
    Jul 2003
    123
    mazak Quick turn nexus 250 ms mazatrol 640t
    Hello Plast-art
    Were i work we have a new lathe with live turret
    nobody knows how to turn it on, or how to run it?
    can't even get the spindle to turn on?
    what is step one
    what is the propper way to home out the machine when it come on.
    any help at all ?
    I dont want to go in to it blind
    company has sent 4 men to learn how to run it
    none of them know how after going to the mazak school
    the parts are needed to run are not that hard to make
    or lots of different ones.
    thanks sidecar82
    Jan 2007
    3
    Sorry, I have a milling 3 axes.
    I have no idea how to start it.
    May 2007
    71
    Write FIL, Just for your ref.......
    TCF=0 $$ SET TOOL CONTROL FLAG TO ZERO
    CIMFIL/ON,LOADTL $$ TRAP LOADTL(TOOLCHANGE)
    TNM=POSTF(7,4) $$ CAPTURE TOOL #
    HNM=POSTF(7,8) $$ CAPTURE HEIGHT OFFSET #
    RSLT=POSTF(2,1,1867,1) $$ SIMULATION MODE ON
    RSLT=POSTF(13) $$ EXECUTE THE CURRENT CL RECORD
    RSLT=POSTF(2,1,1867,0) $$ SIMULATION MODE OFF
    TCF=1 $$ SET TOOL CONTROL FLAG VARIABLE
    CIMFIL/OFF $$ END ROUTINE
    CIMFIL/ON,SPINDL $$ TRAP SPINDL(SPINDLE)
    RTP=POSTF(7,4) $$ CAPTURE RPM VALUE
    SPD=POSTF(7,5) $$ CAPTURE SPEED VALUE
    DIR=POSTF(1,1,1513) $$ SET DIR TO CURRENT INTEGER CODE VALUE
    CIMFIL/ON,COOLNT $$ TRAP COOLNT(COOLANT)
    CNT=POSTF(1,1,1962) $$ SET CNT TO CURRENT INTEGER CODE VALUE
    CIMFIL/ON,GOTO $$ TRAP FIRST GOTO STATEMENT
    RSLT=POSTF(20)
    IF (TCF.EQ.1) THEN
    RSLT=POSTF(21)
    CURX=POSTF(1,3,315) $$ CAPTURE X VALUE
    CURY=POSTF(1,3,316) $$ CAPTURE Y VALUE
    CURZ=POSTF(1,3,317) $$ CAPTURE Z VALUE
    CURA=POSTF(1,3,292)
    CURC=POSTF(1,3,294)
    INSERT/'M5$'
    INSERT/'G91G00G28Z0.$'
    INSERT/'G91G00G28X0.Y0.$'
    IF(NXTTL.GT.0)THEN
    POSTN/IN,20,TNM,T,nxttl,13,6 $$ OUTPUT TOOL # AND M6
    ELSE
    POSTN/IN,20,TNM,T,0,13,6
    ENDIF
    POSTN/IN,7,0,u,FXT,24,CURX,25,CURY,3,CURC,1,CURA,19,SPD, 13,DIR $$ OUTPUT XY S AND M3
    POSTN/IN,7,43,8,HNM,26,CURZ,13,CNT $$ OUTPUT G43 H Z AND M8
    OPFLG=0
    TCF=0 $$ RESET TOOL CONTROL FLAG TO ZERO
    ELSE
    RSLT=POSTF(21) $$ SEND RECORD TO POST
    RSLT=POSTF(13)
    ENDIF
    CIMFIL/OFF
    CIMFIL/ON,SELECT $$ Output Fixture Offset with XY G
    rslt=POSTF(20)
    fxt=POSTF(7,4) $$ Get G54 H
    IF(FXT.EQ.0)FXT=54
    IF(OPFLG.EQ.1)THEN
    POSTN/IN,U,FXT,NEXT
    ENDIF
    CIMFIL/OFF
