603,953 active members*
3,726 visitors online*
IndustryArena Forum > Material Technology > Glass, Plastic and Stone > Spindle advice for marble and stone
Results 1 to 5 of 5
mugabe Spindle advice for marble and... 05-28-2007, 12:19 PM
mugabe I so Colombo spidle, yet... 05-30-2007, 01:51 AM
mugabe Does somebody mind to share... 06-01-2007, 07:59 PM
Egar Twins try to find a belt driven... 06-02-2007, 04:34 PM
mugabe Thanks for info. As far... 06-02-2007, 06:50 PM
    Jan 2007
    124
    Does somebody mind to share maximum radial and axial forces to be experienced during marble and stone engraving ?
    Feb 2005
    51
    try to find a belt driven spindle that holds at least 10000 RPM you will never use it over 8000 for stone but overgun it so you are not maxing out...you will need a sealed high speed bearing...sks has a fine selection for any application. Dont feed at greater then 4 inches a minute when plunging/engraving and spin at high RPMs between 7000 and 10000 depending on the tool....you will find that an engaving bit is only as strong as the speed you spin it....load should read no more then about 8%
  1. Planning a mill, need spindle motor advice
    By MrRage in forum Uncategorised MetalWorking Machines
    Last Post: 09-26-2005, 09:38 PM
  2. Bob-Cad V18 Stone
    By Tazzer in forum BobCad-Cam
    Last Post: 09-19-2005, 05:11 PM
  3. Need advice on Spindle Drive
    By K. R.Giridharan in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-14-2005, 09:05 AM
  4. Seeking advice on Bosch Rotocut as spindle
    By abasir in forum DIY CNC Router Table Machines
    Last Post: 06-16-2005, 09:13 AM
  5. CNC + stone
    By Pruski in forum Glass, Plastic and Stone
    Last Post: 08-15-2004, 07:21 PM
