587,656 active members*
6,673 visitors online*
Results 1 to 13 of 13
    Mar 2007
    79
    Monster Router Update..
    You may remember from a few months ago, I was planning on building a big router. Well, time to ice down the ol' credit cards, parts are coming in next week!
    Details are this:
    2 x 3 x 1 meter work envelope
    THK 30mm SHS rails all around
    THK 50mm Diameter ball screws on all three axes, all with rotating ball nuts.
    2 sealed, caged ball bearing blocks on each rail
    Steel frame, bolted, not welded
    4x6" rectangle tube, quarter inch wall
    3x4" rectangle wall, 5/16 inch wall
    Total mass looks to be in the 3000 lb range, minus servos and table top. Thanks to the people who gave me the advice of "Figure out the weight before you size your servos! They're heavier than you think!" I'm always building stuff, but this one really shocked me - almost 500 lbs for the gantry!
    Here's MY big piece of advice to all of you who have a big, expensive project in mind..
    CHECK DIFFERENT DISTRIBUTORS FOR YOUR LINEAR COMPONENTS!!!
    Even if they all come from the same manufacturer, the cost differences can be HUGE!
    Example, one place quoted me $1920 for a SINGLE 3 meter long, 30mm rail with one block, with 10 weeks shipped from Japan.
    The next place quoted me $570 for the exact same rail, and $240 for TWO blocks.... ships from Ohio, IN A WEEK.
    All told, going to a different distributor saved me over $4000 and NINE WEEKS. Thank you Kaman! (serving New York City)
    Also, for anybody wanting to build a good, small machine, the http://www.tos-world.com/ website is pretty good, plus it illustrates a pretty good point... which surprised the hell out of me...Using a rotating ball nut is CHEAPER than using a fixed nut and rotating screw when you factor in the expense of using two proper bearing blocks at each end of the rotating screw PLUS your regular ball nut.
    May 2005
    674
    Good work on the pricing. Good choice of components as well. What'd you pay for the ballscrews and nuts?
    Feb 2007
    47
    Would love to see the details of your design.
    Such as dual drive or single on lthe 2m/3m axis's?
    I assume servos instead of steppers?
    Ballscrew/nuts P/Ns?
    How do you handle thermal expansion on screws at their ends?
    Drawings?
    Mar 2007
    79
    Prices of the parts are as follows:
    50mm rotating ball nut - $682 Each
    3 meter rolled ball screw - $1415 each (I bought two)
    ( I think a 4 meter screw was only about $1700 and change)
    SHS30 - 30 mm rail prices as follows
    1 Meter - Each $195
    2 Meter - Each $390
    3 Meter, - Each $575
    Pre-loaded block, sealed, standard length caged ball for 30 mm rail, each $110
    Pre-loaded block, sealed, long length caged ball for 30 mm rail, each $120
    I'm using the long blocks on the X and Y, and the standard for the Z. Each rail has two blocks on it.
    Andy
    Feb 2007
    47
    Man I sure hope you do a build log.
    Are you paying someone to build it or doing it yourself?
    Mar 2007
    79
    I do plan on doing a build log, but right now, I'm just concerned with finalizing the cut list so I can get the 3000 lbs and 40' long sections of steel out of the courtyard at the shop.... and between working, life, and debugging the nixie clock my girlfriend is building... well time is just at a premium.
    And for the second question, YES I AM building it myself. My good friend has a metal shop in the same building, so I'll be using him and his tools to do the steel fabrication, plus he's got the mill and the lathe and CNC plasma, and anything I need to have CNC milled I can get done as a favor at another place too. I have a background in industrial automation, so while this is a big daunting project, I do know that I can see it through.
    I'll throw up a link as soon as I have something.
    Andy
    May 2006
    2420
    We will need pics of that beast
    Did I read correctly that you want 1 metre of Z travel ?
    Russell
    Mar 2007
    79
    You're correct, I do WANT 1 meter of Z, but I can't have it :-) My components are only that long! Ideally, I would have more ceiling space too. I'll tell you though, with a bolted setup, I can always drop another few thousand and hook up taller gantry sections and a longer Z. In an ideal world, I'd have enough Z to throw an entire block of GeoFoam on the machine. Right now, I think I'd have trouble even getting a block of it in my shop!
    Andy
    May 2003
    792
    Great thread!
    Jan 2007
    124
    Quote Originally Posted by ewest View Post
    imho, very good point. It is especially important for long axis where screw is vibrating due to its weight and length.
    And less inertia for the motor to handle .
    Thanks.
    Mar 2007
    79
    Good news - an 18-wheeler just pulled up to my shop, and unloaded two long, skinny crates...FULL OF BALL SCREWS AND LINEAR RAILS!! WHOOO!!
    Will send pictures! I'm also working on the build-log web site.
    Will post a link soon as well.
    Andy
    Apr 2007
    1955
    I may need to re-think part of my project. Those rail / carrige prices are substantially cheaper than the probably lesser components I was planning to use.
    Feb 2007
    47
    Still wondering what method you emply to accomodate temp change length of screws.
    Maybe one end fixed and the other that can expand/shrink axially into a keyed/spline?
  1. Homemade CNC Router table update
    By monte55 in forum DIY CNC Router Table Machines
    Last Post: 03-03-2007, 01:02 AM
  2. Thanks Dave! (S4 Monster)
    By David Bord in forum SprutCAM
    Last Post: 11-15-2006, 11:39 AM
  3. Bohner & Koehle Monster Mill?
    By Stuff-Builder in forum Uncategorised MetalWorking Machines
    Last Post: 03-28-2006, 10:56 PM
  4. Update for my router.
    By MonoNeuron in forum DIY CNC Router Table Machines
    Last Post: 02-02-2005, 01:09 PM
  5. My Router - NEW PICTURE UPDATE !
    By ninewgt in forum DIY CNC Router Table Machines
    Last Post: 08-19-2003, 12:51 AM
