587,321 active members*
3,404 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Drill Multiple Holes - Newbie Question
Results 1 to 6 of 6
    Feb 2007
    16
    Hello again,
    I have another question for everyone out there which I am struggling to find an answer.
    I have a 4mm drill bit attached to my router and I want to drill 8192 4mm holes in an 8ft X 4ft sheet of MDF.
    I dont want the bit to plunge down, go round the cirlcle then back out. I want to move to point - plunge down - and lift back out.
    I have marked my holes on my drawings with points, not circles so I am not able to just cut auto.
    I hope I have been clear in describing my problem and would be very greatful if someone could help me out once again.
    Thank you,
    Dan.
    Feb 2007
    16
    If I Use spot drill my controller returns this error for every point...
    "A move has been specified but no motion mode (G00, G01, G02, or G03) has been indicated"
    Thanks once again.
    Aug 2003
    449
    What ype of controller are you using? You will want to use a Drilling Cycle if possible. This should already be in your post.
    1.Click on Machine => Drill and Cycles. It will open a dialog.
    2.Select the Spot Drill, if it is available, and click OK.
    3.Select your Point/Points and right click.
    4.Fill out the dialog and click OK again. Your code will be generated.
    Those are the steps needed to Drill in BobCAD.
    Dec 2006
    51
    I have a Simpl Drilling Demo Video for BCC V21 that I just completed.
    It's a 9MB WMV file.
    If you leave your E-mail address, and can reeceive a 9MB attachment, I'll send it to you and you can test it out for me.
    Feb 2007
    16
    Thanks for all the comments, I would really appreciate it if you could send me the video to [email protected]
    Thanks once again.
    Oct 2005
    859
    Have you seen Sorin's videos? (he does the seminars for Bobcad)
    He has several free vids that walk through many of the operations.
    Go to his sight (got his own sight so he can post his videos).
    When you sign up to his forum you get access to the videos.
    http://cadcamtrainer.com/forums/index.php
  1. Q: Drill diameter for reamed holes.
    By Deviant in forum MetalWork Discussion
    Last Post: 01-11-2019, 10:30 PM
  2. Drill holes with end mill or twist drill ?
    By Argofanatic in forum MetalWork Discussion
    Last Post: 12-30-2006, 05:05 AM
  3. drill dwell between holes
    By EVERFABCHAD in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 08-11-2006, 01:15 PM
  4. Drill holes for flat cap screw
    By starCNC in forum Uncategorised MetalWorking Machines
    Last Post: 09-09-2004, 03:47 PM
  5. Newbie question on drill bits
    By ezland00 in forum DIY CNC Router Table Machines
    Last Post: 02-27-2004, 09:53 PM
