587,999 active members*
4,844 visitors online*
Results 1 to 11 of 11
    Mar 2007
    23
    Question Roll form tapping questions
    Does anyone know how large of a thread can be roll form tapped and how well does it work in cold rolled steel and stainless and brass for that matter?
    I have used roll form taps in the past but only in aluminum and sizes less than 1/4".
    I also wonder about using them in a comp/ret tap driver in my VF-2.
    I'll bet at least one of you guys has experimented with all of the available options.
    I'm trying to first elminate digging chips out of blind holes, and second, cut down on tap breakage. Seems like I heard somewhere that roll form taps take less torque and provide a better thread.
    Any experiece in this area would certainly be of help.
    Thanks:wave:
    steve
    they can be used on steels ,
    never tryed brass , but i can t see why not
    Apr 2007
    64
    at work we tapped 1 inch x 12 tpi in steel.
    we had to make a sleeve for the tap an put
    it into a 1 inch cat 40 holder. there is a hole
    in the sleeve for the set screw and a flat on
    the tap. we have tapped thru 2.5 inches thick
    without problem. the only special thing we do
    is mix grease with tapping fluid an coat both the
    tap and the hole. since we have to make the
    threads to a class 2b tolerance we just have
    to keep an eye on the compression/minor diameter.
    we have a vf2 with a geared head.
    Feb 2007
    36
    i have never used roll taps, but I have thread milled before with very good results. You can go as big as you want and are very easy to program.
    Feb 2007
    19
    95% of the metal I machine is 304L stainless. And roll form tapping is all I will do. It is virtually maintenance free when set up right. Here is a link for a Balax tap catalogue. It has some very usefull info in it.
    http://www.balax.com/catalog.pdf
    Mar 2007
    23
    Thanks you guys. And Taylors, I've saved the link for future use, looks like it should answer all my questions.
    Apr 2003
    1876
    I've done brass, it works good. I made a small (and free) program to calculate tap drill sizes, and it includes form taps.
    Be careful, some customers don't allow form taps on certain parts.
    Matt
    San Diego, Ca
    ___ o o o_
    [l_,[_____],
    l---L - □lllllll□-
    ( )_) ( )_)--)_)
    Feb 2011
    We are roll form tapping a 1 1/6-10 into steel and going completly thru the part which is 6" long , im currently searching for the best speed for that application, and we are doing this on a lathe.
    Any advice would be taken.
    Thanks,
    James
    Aug 2010
    579
    How big is the material?
    How much does it weigh?
    How well are you holding it?
    What type of steel?
    Who manufactures the tap?
    What coating does the tap have?
    What coolant are you using?
    How much coolant are you using?
    Are you currently experiencing problems?
    What size lathe do you have?
    Thanks,
    Ken Foulks
    Feb 2011
    Quote Originally Posted by KenFoulks View Post
    What type of steel?
    The Material is only 1 5/8 dia. and we are holding it in a collet chuck with serrated jaws and material is 4140 steel. Tap is an OSG tap with a coating but not sure which it is, and we are using Consultant Lubricants Full Synthetic at a 8 on the refracometer. This is currently working just fine and we are using a Doosan 2500, only lathe we had with enough umph and holding force.
    Aug 2010
    579
    (wrong)
    OSG only carries taps up to 3/4". They do make custom taps, here are their recommendations, based on coating:
    Premium 25-30 SFM
    Standard 20 SFM
    The Doosan 2500 only has 20hp, the same as a Haas ST-20.
    Thanks,
    Ken Foulks
  1. Simple question: Hot roll vs cold roll steel
    By CuttersCov in forum MetalWork Discussion
    Last Post: 01-10-2013, 02:42 PM
  2. Vacuum Form Machine Questions?
    By AmazinJane in forum Vacuum forming, Thermoforming etc
    Last Post: 10-25-2011, 05:03 AM
  3. 1/4" mat'l vac form questions
    By elmosxyls in forum Vacuum forming, Thermoforming etc
    Last Post: 02-09-2011, 03:30 AM
  4. A few questions about a reverse tapping head.
    By l u k e in forum MetalWork Discussion
    Last Post: 09-20-2006, 02:30 PM
  5. tapping head vs hand/cordless tapping machine....
    By InspirationTool in forum Uncategorised MetalWorking Machines
    Last Post: 09-13-2005, 02:10 AM
