588,484 active members*
5,233 visitors online*
IndustryArena Forum > CNC Electronics > Phase Converters > Converting to a VFD - several questions
Results 1 to 10 of 10
    Apr 2007
    175
    Please forgive me, I'm still noobish to the DIY CNC routine. I've searched and didn't find what I was looking for, but perhaps, I am looking for the wrong thing.
    I have a grizzly G3617 that I have started purchasing the parts to convert it to CNC. I have the servos already, some of the necessary tooling etc...but I had questions in regards to the VFD conversion process.
    The pulley/belt arrangement on this thing is a major PITA to change. I want to change to a variable frequency drive - but I have very little idea of what needs to be done.
    At the very least I'd like to maintain the speed the machine was able to do from the factory 3600 RPM, more would be very nice though...all without changing belts anymore
    Can tapping be done once changed to a VFD? I'm assuming the motor would need some sort of encoder system on it, correct?
    What other things need to be considered? Can MACH3 control the VFD?
    Sorry if there are any terribly obvious questions...
    Dec 2003
    24221
    You will need a 3 phase motor as well as the VFD.
    To do synchronous tapping, you will need a system that syncronizes the Z axis to the spindle encoder.
    You may get away with floating tapping, depending how well the control of your spindle is, usually requiring fast accel/decel of the spindle.
    Depending again on the VFD, you may require to retain one reduction to go down to low speeds.
    If you get a 4 pole motor, you can generally run at 2x base frequency ( 120hz instead of 60hz).
    Al.
    Albert E.
    Apr 2007
    175
    Ah.. I see.. Well, if it requires a 3 phase setup, I won't be able to do that without some sort of phase converter. No 3 phase avaialble in the neighborhood here. Are there other alternatives?
    I thought about the 1 reduction already, I figured it would be needed to run the bigger stuff slower and still have some usable torque.
    Dec 2003
    24221
    I should have explained, you do not need 3 phase as the VFD will accept 1 phase in and output three phase, it produces 3ph electronically.
    Most 3ph motors go down to 220v so it is normal to input 240 1ph which you should have in your panel.
    Al.
    Albert E.
    Apr 2007
    175
    Ohh.. Now it all makes sense. I didn't think all of these DIY'ers had 3 phase!
    What things should I pay particular attention to when I look for a VFD and motor?
    Do you happen to know if MACH3 can control the VFD?
    Thanks Al!
    Dec 2003
    24221
    Look for a good quality if used such as Baldor etc, if buying new, check if the motor is invertor or vector rated.
    If you get a 4 pole 1725rpm, you should be able to run at 120hz which will give you close to 3400 rpm.
    Most VFD's have a ±10vdc control, so you will need a pwm to analogue convertor, If you search here there should be a link, unless someone can point to a link.
    Al.
    Albert E.
    May 2005
    1810
    Here is a link to the speed board I am using:
    http://www.cnc4pc.com/Store/osc/index.php?cPath=25
    If you have yet to purchase your BOB, I would suggest getting this board from cnc4pc:
    http://www.cnc4pc.com/Store/osc/prod...products_id=48
    Also, see the following thread for more info:
    http://www.cnczone.com/forums/showthread.php?t=15600
    Scott
    Consistency is a good thing....unless you're consistently an idiot.
    Apr 2005
    403
    Turbostang,
    Just download a manual from driveswarehouse and read through it and it will begin to make sense.
    As far as tapping, I use a tapping head. You still need to pay attention to the RPM as you go down with the tap (-Zfeed rate) and with my tapping head it automatically reverses at 1.6 times the speed when you back out(+ Z feed)
    So, if you mount a spindle speed monitoring circuit (I did this on a couple of lathe conversion in the mini lathe forum in order to do automated thread cutting) I would think you can specify the feed per rpm in mach 3 for your tapping head for both forward (going into the hole) and reverse (coming out of the hole).
    Ron
    Mar 2008
    40
    Hard to deal with CNC4PC.Com?
    Hi, just jumping into the thread here-
    Regarding http://www.cnc4pc.com/Store/osc/prod...products_id=48
    Thanks for the URL, except... they changed their site and that URL does not go to a product anymore. So I called the number on the website before 4 pm their local time, and the phone rang and rang without any answering machine.
    What specific product are you using from cnc4pc? (I'd like to find it if it's better/cheaper than BOB.)
    Thanks! Diy-Guy "Becoming a little more than a newbie."
    Quote Originally Posted by mxtras View Post
    Scott
    May 2005
    1810
    Quote Originally Posted by DIY-Guy View Post
    Thanks for the URL, except... they changed their site.
    They have changed the board a bit also, but this is the board:
    http://www.cnc4pc.com/Store/osc/prod...8926cd6e3b90c0
    Scott
  1. Brass vs Aluminium Vs Steel, questions, questions and questions...
    By alexccmeister in forum Uncategorised MetalWorking Machines
    Last Post: 08-15-2011, 06:40 PM
  2. Converting N/m to oz/in
    By flybynight in forum DIY CNC Router Table Machines
    Last Post: 03-23-2011, 07:14 PM
  3. Questions on Converting the Sieg X3.
    By Willyb in forum Benchtop Machines
    Last Post: 10-13-2005, 12:44 PM
  4. converting to dfx
    By qsacracer in forum G-Code Programing
    Last Post: 04-26-2005, 09:43 PM
  5. Converting 3-in-1 Machines to CNC
    By GunnySnow in forum Uncategorised MetalWorking Machines
    Last Post: 09-11-2003, 03:46 PM
