588,490 active members*
4,546 visitors online*
Results 1 to 3 of 3
    Jan 2007
    61
    Haas rapid move ?
    Ok so one haas the rapid moves follow just like gibbs cam shows, the other haas machine doesnt? Its hard to judge where to put the clamps.
    Oct 2006
    125
    slow you rapids on the first pass
    4826
    Solution: don't rapid so close to your surface that you cannot clear the clamps
    In rapid traverse, both X and Y move at full speed simultaneously (looks like a 45 degree angle), until either of them reaches its endpoint, then the remaining axis continues to move alone. So it will look like a combination of 45 degree moves, finished with moves parallel to one axis.
    A more modern cnc may have enough capability to actually perform an interpolated move at rapid speed, I know I had the option to pick either mode on a Mitsubishi cnc.
    You will have to visualize how this works, because the CAM software most likely calculates an interpolated path (bee-line) between two points.
    Run the graphic check on the Haas to double check, I think it shows the actual rapid path.
    First you get good, then you get fast. Then grouchiness sets in.
  1. rapid speed
    By contractdesign in forum Bridgeport / Hardinge Mills
    Last Post: 06-04-2007, 03:23 PM
  2. Crash during Z rapid move
    By AndyB in forum Fadal
    Last Post: 03-07-2007, 03:48 PM
  3. Rapid moves G00
    By dicksonhof in forum Mach Software (ArtSoft software)
    Last Post: 11-07-2006, 04:21 PM
  4. The X-Axles... to move or not to move!
    By Wild4aces in forum Mechanical Calculations/Engineering Design
    Last Post: 03-18-2005, 08:26 PM
