587,188 active members*
4,841 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Specific drill bit needed ?
Results 1 to 3 of 3
    Jan 2007
    61
    I've got to drill ALLOT of holes in the Black Acrylic panel
    I’m using to cover the PCB. Around 768 of them !
    I got a good DIY CNC machine that uses a dermel tool for the spindle.
    I think it will do the job and I’m currently designing the CAM file for drilling the holes.
    However, I need a drill bit that can cut a 13/64, and at the same time fit into a dremel tool which is 1/8 inch shank.
    Does anyone know where can I find this? Is there an alternative solution I can use?
    What do other people use ? I thought about this bit
    http://www.truebite.com/drill_degrout/
    It’s part no# 6050 – but will it not remove a plug of the material and clog the bit each time I plunge through the material?
    I really ned some help, I don’t know what to do.
    Thanks,
    Oct 2006
    51
    you can get a carbide circuit board drill in that size with an 1/8" shank.
    .500 flute. they are about $20 each at msc.
    Jan 2007
    61
    Thanks Hirah !
    Yes they have one, I've looked everywhere for
    a bit like this, Thanks !
    It's msc part no. #00901132
  1. Specific (CNC) code request.
    By Karol in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 06-23-2007, 03:30 AM
  2. Replies: 7
    Last Post: 05-14-2007, 06:31 PM
  3. Specific purpose for Vcarve
    By Hack in forum Vectric
    Last Post: 04-04-2007, 03:20 PM
  4. Which mill for specific job
    By fatboy55 in forum Benchtop Machines
    Last Post: 08-06-2006, 02:36 AM
  5. Specific Power supply ?
    By boxwood in forum CNC Machine Related Electronics
    Last Post: 05-17-2003, 06:26 PM
