588,529 active members*
6,278 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > OKUMA LB 15 OSP5020L How do I activate foot pedals?
Results 1 to 7 of 7
    Jul 2007
    4
    I have recently purchased an okuma lb 15 lathe. I have pretty much figured out everything on the machine except the foot pedals for the chuck and tail stock. The machine is set up with a bar feeder. I can open and close the chuck thru mdi with an m83 m84 but nothing happens when I step on the pedal. Is there an m code to activate the foot pedals or what? Anyone have a list of m & g codes for this machine they can send me?
    Thanks Duane
    Oct 2005
    162
    have you check if the machine is on machine lock?
    On the other hand, You have different fingers.
    Jul 2007
    4
    I got it working now. There is a saftyl lock on the foot pedal. I was not putting my foot in far enough to release the safety. Tail stock still doesn't work but I have to fix a couple of broken wires. found some g & m codes on the net. Thanks
    Sep 2007
    44
    As regards to the foot pedals for the tailstock, they won't function unless you have the tailstock enabled in the parameters menu.
    Jun 2005
    194
    M56/M57 ... by the way you might find this site usefule: http://www.countyhistory.com/rbcreat...perations.html
    JR Walcott
    Georgia Machine Tool Resources, LLC
    May 2015
    Re: OKUMA LB 15 OSP5020L How do I activate foot pedals?
    need control file and postprocessor okuma genos l250 mastercam x5
    Dec 2008
    3142
    Quote Originally Posted by nichacoon View Post
    To operate the foot pedals ?? (chair)
  1. x6 Okuma lathe osp5020l
    By 1neil in forum Mastercam
    Last Post: 03-31-2014, 01:03 AM
  2. Okuma OSP5020L DNC problem
    By Hemi8146 in forum Okuma
    Last Post: 10-18-2012, 02:44 PM
  3. Okuma LNC 8 with OSP5020L
    By robsmetalcraft in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-15-2010, 02:22 AM
  4. Okuma OSP5020L
    By MKATool in forum Okuma
    Last Post: 06-27-2008, 06:05 AM
  5. Okuma OSP5020L Backlash compensation
    By Rocksalt in forum DNC Problems and Solutions
    Last Post: 02-12-2006, 02:13 AM
