587,237 active members*
3,759 visitors online*
IndustryArena Forum > Hobby Projects > I.C. Engines > looking for four stroke plans
Results 1 to 8 of 8
    Jun 2007
    18
    looking for any push rod or sohc engine plans
    ignore the spelling mistake
    Feb 2007
    64
    im not sure what those are yet, but have you seen this.
    http://home.comcast.net/~webster_engines/
    Jun 2007
    18
    yeah looking for sumpthing a bit more up scale
    Mar 2005
    1136
    stem, have you seen Eric Whittles air cooled V8? very nice engine, fits in your hand and representative of a wwI aeroengine. was printed as a series in ME a few years ago. if you go the chaski home machinist site and check out the IC section, there is a link posted to some scans.
    there are many many successful designs out there that have published over the years. subscribe some of the mags, join model engineer forums or just surf, for sure see something that catches your eye
    Apr 2007
    13
    Stem, Look in Model Engineer from 13 April 2006. Plans and construction notes have been serialised in alternate issues.
    I have made it and it runs well. No gears to make and will run as Glow plug or spark ignition.
    Would post a pic if I knew how.
    Mago
    Feb 2007
    64
    Mago, go to putfile.com and make an acount, load the pic up on there then put the html (it should have all the code to post it already)
    if not send the pic to me and i can put it up for you?
    [email protected]
    Dec 2005
    430
    all u have to do is go to the "manage attachments" button on the lower part of the page when u press "post reply", find your pic on your harddrive and click "uplaod"
    Feb 2007
    64
    The model is NE15S designed by "Nemett" and serialised in Model Engineer.
    Plans may by bought directly from the designer.
    The model is about 15cc capacity with a 25mm bore. it is wet sumped and splash lubrication means no oil pump. the single cam drive is by toothed belt so no gears to cut. Cams are cut on the bench mill using a rotary table. A pair made together, then separated, case hardened and Loctited to the cam shaft. Bearings are roller or ball. You'll love this, dimensions in metric.
    Mago
    hope it worked
    i put the text up Mago.
    looks great and i love it!
  1. two stroke engine
    By PoWaKiD42 in forum I.C. Engines
    Last Post: 10-03-2007, 06:59 AM
  2. anybody with 2 stroke plans
    By stem fan1 in forum I.C. Engines
    Last Post: 09-28-2007, 02:08 PM
  3. 2 stroke porting
    By Tom Brown in forum I.C. Engines
    Last Post: 09-05-2006, 08:48 PM
  4. Hypothetical 2 stroke v-8
    By jrc347 in forum I.C. Engines
    Last Post: 06-16-2006, 01:16 AM
  5. 4 stroke engine: castings & plans
    By motordude in forum I.C. Engines
    Last Post: 03-02-2004, 05:08 PM
