I should have remembered to mention that; I modified mine so that it would ask for a number upon posting cuz I always forgot to input the misc variable
Insanity "doing the same thing and expecting a different result"
Mark
www.mcoates.com
Thanks, rickyt and marc
I will give that a try. Sounds like what I am looking for....
Also Geof & Tim you both said to use sub's not sure if i am missing something but some operations do not give you the sub option(ex. Face Milling) do you guys just turn that into a sub manually?
What I am trying to do is call up a tool and use it on all WCS and then call up the next tool and use it on all WCS and so on....
Thanks allot for the Help guys.
