587,980 active members*
3,993 visitors online*
Results 1 to 6 of 6
    Aug 2007
    7
    Lathe C-axis post
    hey all, I recently got a lynx 220LM and I use Mastercam X to program, but I am having trouble posting. right now my post is outputting for Y-axis moves instead of C rotary motion, does anyone have a post that works good for the application?
    Feb 2006
    992
    I believe under toolpath Parameter you can change Y-axis option to C-axis ..... that's it.
    The best way to learn is trial error.
    Aug 2005
    578
    Have you spoken to your reseller about fixing your post for you or pointing you in the right direction? My reseller is more than happy to provide those services. usually for free.
    Emastercam is also a great resource for post edits.
    Now that you've spent the money for a live tooled lathe, have you thought about upgrading to X2 in order to get the additional toolpaths?
    Aug 2007
    7
    well I have not had the chance to read any reviews but what are the toolpath advantages to X2? and no I have not cotacted my dealer, I suppose that would be my best option but I think it will take them at least a few days of which I dont really want to spend. I was hoping someone on the forum had one easily available
    Jan 2006
    4396
    Quote Originally Posted by CNCaveman View Post
    If you post this in the Mastercam Sub-Forum here in CNC Zone some of the Mastercam Gurus will be able to help you Edit your Post Processor. Then again they also hang out on the EMastercam Forum.
    Here http://www.emastercam.com/
    Cheers!!!!!
    Toby D.
    "Imagination and Memory are but one thing, but for divers considerations have divers names"
    Schwarzwald
    www.refractotech.com
    Dec 2005
    3
    What post are you using? mplfan works as long as you turn misc. integer 4(g112/g107 enable) off.This will post all c axis interpulation into a bunch of straight lines, it runs great but takes up alot of code.
  1. 5 axis lathe post
    By banditxx in forum EdgeCam
    Last Post: 07-20-2007, 02:18 PM
  2. Post Processor for KiaTurn 21LMS 4 axis lathe
    By bigcorey in forum Mastercam
    Last Post: 05-11-2006, 03:34 PM
  3. OneCNC XR & XR2 with 4th/5th axis, and OneCNC Lathe XR, post for Mach 3
    By PoppaBear10 in forum Screen Layouts, Post Processors & Misc
    Last Post: 01-25-2006, 11:21 PM
