587,560 active members*
3,436 visitors online*
    Jan 2006
    Metric or Imperial Ball Screws
    Hi
    First post here. I am about to buy an X2 Mill and plan to convert it to CNC. I have found a heap of different conversions on the net and have pretty much worked out how I am going to do it.
    I am trying to work out where to source a balls screw and nut for the Z axis, most of the conversion plans from the US use imperial ball screws, I thought it would be better to stick to metric as that is what I am used to. Seems like 16mm X 5mm would be a close equivalent to the 5/8" screws specified.
    Any suggestions?
    Chris
    Springwood, NSW
    May 2006
    22
    Mill Conversion
    Chris,
    I've just received 16 mm x 2.5 mm ballscrews from "Marchantdice" in the UK
    Although listed as rolled , they look like ground, as the finish is so good.
    Took about two weeks to get to me.
    Look up their web site through Google.
    Also, if you can get hold of them, the UK magazine 'Model Engineers Workshop', issues 102, 103 & 104 has a first class set of articles on conversion of an X3. If you can't get the articles, e-mail me and I help all I can
    Jan 2006
    Thanks for the help. They look like a good source. Chris
    Jul 2007
    32
    Ballscrews
    Drop me a PM or [email protected]
    I can get rolled or ground screws at a great price. Any length you want upto 4m and most metric sizes.
    Todd
  1. Metric Ball screw suppliers
    By marting in forum Uncategorised MetalWorking Machines
    Last Post: 06-26-2007, 11:35 AM
  2. Converting from metric to imperial
    By Pharkas in forum Mastercam
    Last Post: 05-04-2007, 04:46 PM
  3. Ball screws, Acme screws, threaded rod
    By DJ Morrow in forum DIY CNC Router Table Machines
    Last Post: 03-22-2007, 06:39 PM
  4. Metric mm or Imperial inches? Please help.
    By alexccmeister in forum Benchtop Machines
    Last Post: 02-22-2007, 03:19 AM
  5. Is it legal to mix inch and metric ball screws?
    By dmgdesigns in forum DIY CNC Router Table Machines
    Last Post: 04-13-2004, 05:52 PM
