587,834 active members*
3,148 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Saw Arbor- where and what is this?
Results 1 to 14 of 14
    Apr 2007
    15
    Hello all. I really don't know if this is the correct place to post but I've been google'n for a good hour and I can't find anything like this. I found lots of arbors but none like the photo below:
    I want to setup a rig to use a saw arbor attached to a pulley like pictured above. Are there anything like it or do I have to custom make it? I was thinking buying an arbor and extending it, adding bearings on both ends, then attaching the pulley. Any insight would be great!
    Aug 2005
    5
    I would start by looking for jack shaft assemblies . But everything you have there should be available at your local hardware store .
    746
    Most of the ones that I've seen have had bronze bushings in them vs. ball bearings. Any good old time hardware store should have them.
    If it's not nailed down, it's mine.
    If I can pry it loose, it's not nailed down.
    Apr 2007
    15
    thanks. I'll check ace hardware=) searched for jack shaft assemblies and found nothing of interest.
    Apr 2007
    32
    saw shaft arbor etc.
    What you need is a shaft, 2 pillow ball bearing blocks, a couple shaft collars and an arbor, (preferably with a left hand thread). I can get you the parts needed if you want. I have the arbors that will lock on a 1/2" shaft with a set screw and give you a 1/2" x 20 LH threaded arbor shaft. You can email me direct if you like <[email protected]>
    Oct 2006
    37
    With the orientation shown in the photo in the initial post, a right-hand thread would be proper for the blade retaining nut. The blade support flange should be pinned or strongly thread-locked to the shaft if it is a single-diameter shaft.
    The set-screw arbor adapters were really intended for attachment directly to a motor shaft that can't be machined easily. They are not as good as a properly machined and threaded shaft for balance and concentricity. If itwanabe can't find a ready-made arbor and has access to a lathe, I would recommend necking a next-size-up shaft down to the desired diameter to fit his blade snugly and thread the shaft directly. That will provide excellent concentricity and a shoulder for his blade support flange.
    These "saw arbors" used to be very common items at Sears or any well equipped hardware store but I suppose they are rarely used these days since cheap imported table saws, chop saws, and grinders are readily available.
    awright
    Jan 2006
    21
    Putting a sawblade on that is just asking for trouble. That type of chopsaw is not setup to do that type of work. Just make sure if you do use it that way to remember that it may kick, blade come loose, and keep yopur fingers clear.
    Kevin
    Oct 2006
    37
    itwanabe never actually said what kind of blade he wanted to put on his creation. The photo, which I gather is something he wants to copy or take as a model, looks more like a tile saw with the tray under the cutting area, or an abrasive saw.
    However, Kevin45, aside from the normal high hazard of circular saws, why is the homemade chop saw configuration shown inherently more dangerous than the equivalent purchased miter saw? Of course, any saw would have to have proper support and clamping of the workpiece (which is not visible in the photo) and should have a retractible blade guard and a belt guard, but assuming that those items are provided and well-designed, why is this more dangerous than the equivalent commercial saw?
    awright
    Apr 2007
    32
    Awright, you are correct...it would be a RH thread for counterclockwise rotation. I do have arbors with LH thread for clockwise rotation that are made to go on a 1/2" shaft if needed.
    Jun 2006
    13
    try Grizzly Tool, they sell arbors
    Jun 2006
    13
    Personally, for the money you will waste .....go buy a chop saw
    Mar 2007
    3
    laheyth- Agree: If you value your fingers dump that thing.
    I am usually the sort who hates buying new and would rather fix up anything, but Chinese chop saws are cheap as chips and the ones I've seen come with a hydraulic damper which should help reduce 'snatching' when cutting wood. I think that the contraption shown was intended for tile cutting, though would anyway fill the washing machine- spinner motor- shown, with dust.
    Aug 2005
    231
    Given the V-groove in the table leading up to the recess for the blade, I'm thinking re-bar cutter, or fence / gate (wrought iron bars?) cutter... There's really nothing for a tile to sit on and it looks like an abrasive blade. FWIW, I use a cheap Ryobi mitre saw with a cutoff blade as a chop saw. Works great. If we may ask, what is the final intention of the device you're making with the pulley shaft?
    Nov 2006
    Saw Arbor
    Home Depot sells a 4 1/2 inch circular saw, with water hose attachment and tile blade for around $70.00. I purchased one and screwed an "L" shaped
    plywood bracket / stop to a bench and cut tile ceramic tile for the garage. For the price, you can't beat it.
    DC
  1. 58b stuck arbor.Edit nevermind!
    By grinderdust in forum MetalWork Discussion
    Last Post: 12-27-2006, 06:32 PM
  2. Face/Shell Mill Arbor
    By Zumba in forum Uncategorised MetalWorking Machines
    Last Post: 05-21-2006, 04:01 AM
  3. Recommendation for Shell arbor and mill
    By kdoney in forum MetalWork Discussion
    Last Post: 03-18-2006, 10:37 PM
  4. arbor press pressure
    By MBG in forum MetalWork Discussion
    Last Post: 04-01-2005, 01:26 PM
  5. Need an R8 Shell Mill Arbor
    By CoolHand in forum Uncategorised MetalWorking Machines
    Last Post: 02-03-2004, 03:02 AM
