Originally Posted by
Pete Stenabaugh
Arturo,
I was able to finall get my laser to fire a single shot, thanks to the heads up from Jacqui. I did some more playing and I found that you have to hold the 'TEST' button down, and then while holding it down, you can press the "LASER' button to fire a single shot. I found you need to press the button fairly hard.
I keep learning new things about this machine each time I use it. Quite often I was getting errors about having no connection, it seems as though the link to the USB was being dropped off, so I merely had to unplug and re-insert the usb cable from the laser, into the laptop. It might be a problem with the laptop, I am not sure.
My friend here with the same machine also, has found a bad connection in the small connector on the end of the lead coming from the chiller, that plugs into the lead at the back of the laser. This connection tells the laser that the water is circulating, so if you have trouble check that connection also, or the laser may not fire.
I am not sure about the homing issue yet. I havent really used that feature yet. I have found that the laser 0,0 position can be set from the laser 5.0 software (this does not affect the home position). If you have it set to the centre, then the laser will start the file from what ever position it is sitting in when you turn it on. You dont need to send it home to datum each time.
Although my machine will travel to the upper right corner if I press the datum button, but I dont like that, it takes too long to get it back where I want to use it. I would prefer the datum position to be at the front left corner, so that all positions would be '+' values rather than all '-' values the way they have it set up now. Eventually I will find out how to change the home position to something more practical, but I dont know if I could get a proper answer by asking Frank, he doesnt seem to be too techically informed about these machines, he keeps having to go to the factory, and I think we loose too much information in the process. I am going to try to get an email address for one of their technicians, if they have any that speak proper english so we can get the information sort out.
Pete
