588,548 active members*
5,787 visitors online*
Results 1 to 9 of 9
    Apr 2007
    178
    HAAS Service in the North East
    REYTECH Machine Service Corp.
    P.O.Box 172
    Bellvale, NY 10912-0172
    Ph.(845)521-6052
    FX (845)986-6185
    [email protected]
    !! FOR YOUR HAAS REPAIR NEEDS !!
    servicing NY NJ CT PA and beyond
    !! SERVICE: COURTEOUS, KNOWLEDGEABLE SERVICE BY THE OWNER OF THE COMPANY!!
    !! EXPERIENCE: WE KNOW WHAT BREAKS DOWN, WHY AND HOW TO PREVENT IT!!
    !! BOARD REPAIR: WE REPAIR NUMEROUS HAAS BOARDS TO COMPONENT LEVEL!!
    !! MAINTENANCE: WE OFFER CUSTOM TAILORED MAINTENANCE SERVICES!!
    !! PARTS: WE CARRY AN EXTENSIVE SUPPLY OF COMMON REPAIR PARTS!!
    !! SOLUTIONS: WE SOLVE MOST COMMON HAAS BREAKDOWNS!!
    SHUTTLE FAULTS
    TURRET FAULTS
    GEAR FAULTS
    LOW LUBE ALARMS
    LOW TRANS OIL ALARMS
    LOW AIR PRESSURE ALARMS
    TOOL CLAMP FAULTS
    TOOL UNCLAMP FAULTS
    LIMIT SWITCH FAULTS
    BROKEN WIRES
    BROKEN BELTS
    NOISY RAPID
    WAY COVER REPAIR
    P-COOL FAILURE
    SPINDLE ORIENT FAULTS
    NITROGEN CHARGES
    TURRET CLAMP FAULTS LATHE
    TURRET UNCLAMP FAULTS LATHE
    TURRET CLUNKING LATHE
    A SERVO ERROR LATHE
    PALLET CLAMP / UNCLAMP FAULTS
    GROUND FAULTS
    TRIPPING BREAKERS
    SPINDLE NOISE
    !!!CALL TODAY FOR A FREE CONSULTATION!!!
    WE KNOW WHAT YOUR HAAS NEEDS!
    845-521-6052
    FULLY INSURED
    Aug 2007
    339
    Hass Repair
    What about the Hass Rotary indexer? The last time we needed it repaired we had to send it out to Calif. Took about a month before we got it back. They are so heavy UPS will not take them had to ship freight via tractor trailer. A faster turn around would be nice.
    Apr 2007
    178
    what is wrong with the unit?
    Apr 2007
    178
    the ha5c should be able to go ups if you package it properly, haas sells boxes for like $150.00
    Aug 2007
    339
    It's okey now they fixed it. But the problem it had was it could not find the home position. Just kept on rotating and no Zero could be found. We did what we could. cleaned it out checked the contacts in the box etc. But when it came back it was a major upgrade and rebuild. We havent had any problems sence. But one never knows.. One day we could turn it on and nothing happens. I'm sure it's to do with all the moisture etc. from the coolant getting inside. It would be nice to have options though.....
    Apr 2007
    178
    i cannot repair the mechanic part of it because i cannot get parts unless you order them, and haas will not sell the worm gears to anyone unless they are rotary certified. but no home would be either the cable or the hall effect sensor which can be had easily.
    Aug 2007
    3
    I am looking for some way cover rubber wipers,for a 1996 Haas VF3. I only need the y axis now but whats the cost for the parts on both axis. I plan to change them myself, I just need parts. To be honest I am looking for someone to get the parts from thats cheaper than Haas. Maybe some aftermarket?
    Apr 2007
    178
    93-8500 is about $85.00 that is 24 feet of rubber and should cover both x and y axis. thats only about 3.50 a foot i do not have an aftermarket source fior the rubber but i do have many other parts. For $85.00 it hardly seems worth bothering, just order it from the hfo they do have competitive prices on most things but if you need anything else feel free to contact us.
    Aug 2007
    339
    Thanks Serviceman for responding. Your right, when it came back it did have a brand new cable and they eliminated or changed some of the components in the Black electrical box that mounts to the Indexer. It did need a new gasket (lol) we had that box apart so many times repairing it. But ya know it's been going for 15 years now. We have also upgraded the Control. It's nice. Now that I know of this site I'll be sure to post problems here that we cannot solve in case others have had similar problems and may know a fix or some one such as yourself that even has parts. GREAT SITE !
  1. Looking for a certain HAAS service tech
    By force2eng in forum Haas Mills
    Last Post: 03-07-2009, 12:31 AM
  2. East Tennessee
    By jhwatts in forum Mentors & Apprentice Locator
    Last Post: 01-08-2009, 08:50 PM
  3. Looking for Haas service tech in Southeastern VA
    By HFOSM in forum Employment Opportunity
    Last Post: 10-30-2006, 10:29 PM
  4. Haas service question
    By PBMW in forum Haas Mills
    Last Post: 09-05-2006, 03:00 AM
  5. North East Electronics PNC 4 Control
    By colin1544 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-30-2005, 11:24 PM
