588,555 active members*
4,936 visitors online*
Results 1 to 14 of 14
    Jan 2004
    231
    bistable flip flop
    Hey gang,
    I would like to get ttl logic to toggle back and forth from high to low by pushing on a momentary contact pushbutton.
    any suggestions for a circuit?
    Owen
    Jun 2003
    3312
    Do you mean you want a logic level oscillator to start on the pulsh of a button?
    Phil
    Dec 2003
    24221
    Owen, Do you have a 7474? If I recall from my ttl days wire the PB to the Clock, connect /Q (Q bar out) back to the D input and use the Q output. If I remember correctly this will toggle the output every pulse.
    I will have to dig out my old notes, unless someone has a better idea.
    Al
    BTW tie the clear and set high for normal operation.
    Albert E.
    Jan 2004
    231
    Phil
    Phil, not an oscillator per se. I want to poke a momentary contact switch and have it send a circuit to high and have that circuit stay high. Then I'd like it to send the circuit to lo when it gets pushed again.
    So far I've wired a 555 timer to debounce a push button switch, and now I'm looking for it to flip-flop a ttl circuit.
    owen
    Jun 2003
    3312
    one more question, is the push button double throw? i.e. has normally open and normally closed contacs? The reason I ask is if it has both contacts you can do the dbounce with one half a flip flop.
    Phil
    Jan 2004
    231
    Phil
    single pole.
    Dec 2003
    24221
    This one has worked for me, it has a 7404 debounce circuit into the 7474 dual D flip-flop.
    Al
    Oops I hope I can make the File a bit bigger!
    Jan 2004
    231
    Hoo boy.
    I'm laughing out loud here because I'm really anxious to get a circuit and I clicked on yours and got this unreadable picture.
    Al, could you be kind enough to try to post again, or just send it to [email protected]
    thank much :-)
    owen
    Apr 2004
    678
    I'm glad to see someone still does it this way.
    Give the problem to a student today, and there is a good chance he would come up with a PC Pentium4 3GHz w. 1GB RAM and a VB program to solve your problem. :-)
    Jan 2004
    231
    Al,
    just to follow up, the circuit worked great. I went with using a 555 for the debouncing part because that's what I had on hand. The circuit is included here...
    owen
    Dec 2003
    24221
    Owen, Glad it worked, I date back to when we had to do this at one time with discrete components, that was a challenge!. Hail the IC.
    Al
    Albert E.
    Jan 2004
    231
    Al,
    I think maybe we were separated at birth.
    remember when it wasnt possible to go to the net and get a data sheet on chip?
    because there wasnt a net...
    or computers...
    or chips. :-)
    owen
    Jan 2004
    122
    dunno, looks too hitech to me
    Attached Thumbnails Attached Thumbnails bistable flip flop transistor toggle.gif
    maybe...
    Jan 2004
    231
    yeah I saw that one on the net. I couldnt go with the transistor approach because I'm only operating at 5 volt levels. good to include here if anyone searching this site later on.
    owen
