587,737 active members*
3,238 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Bipolar Microstep 48 volt 5Amp /phase, 4 axis board
Page 13 of 29 3111213141523
Results 241 to 260 of 572
  1. #241
    1050
    Hi Kreutz,
    Still working! wow how minature can solderable electronic parts get!
    Great goin.
    RGDS
    Irfan
  2. #242
    Sep 2006
    104
    a lot smaller... take a look at this: for example http://www.panasonic.com/industrial/...AOA0000CE1.pdf
    I bet hand soldering is a bit tricky on the 01005 parts, the smallest I have done is 0402 and that is doable but not my first choice
  3. #243
    Aug 2006
    2758
    Quote Originally Posted by CountZero View Post
    0402 are also doable without much problems, better with some mechanical aid and vacuum pick, like the manual pick and place stations. Not my choice either, for tweezers and hands free placement...
    I improvised an squeegee using a plastic business card, it worked. My real squeegee should arrive today, the older one is rusted and unusable..
  4. #244
    1050
    I thought that smd's were adhesively placed in the right location and then a solder paste is applied and ket in the soldering oven. is it not so? Phill from pminmo.com had given me a few links- lost long back....
    any one has few tips on the www?
  5. #245
    Aug 2006
    2758
    Quote Originally Posted by contactirfu View Post
    That could be done in order to reflow two sided boards with components on both sides, the adhesive is applied to the bottom side (generally, the side with less components, or less amount of heavy components).
    What I do:
    The solder paste will keep the components attached due to superficial tension, the components will also auto-align themselves within certain limits (if you control vibration and shocks).
    So, first you apply solder paste, then the components (to the side with less components), reflow, then apply solder paste to the other side, place the components, and reflow again. The superficial tension of the solder will hold the components on the bottom side during the second reflow cycle, and there is no need for adhesive (unless there are heavy components on that side). On the other hand, you reflow twice the same board, so it takes more time.
    Adhesive is applied generally to heavy components (e.g. connectors, big inductors, etc) in order to keep them in place.
  6. #246
    1050
    Quote Originally Posted by kreutz View Post
    What I do:
    ThanX Kreutz, that was Informative!
  7. #247
    Aug 2006
    2758
    Reflow profile for this prototype's Reflow cycle
    Preset parameters for this profile:
    Soaking time 150 sec, soaking temperature 168 C, Reflow time 20 sec, Reflow temp 226 C.
    At the end of the cycle, the oven will keep the temperature at 60 deg C. The power curve shows that regulation even with the oven's door opened. After a while it disconnects itself and ask for the next batch.
  8. #248
    1050
    OH Kreutz, its overload ,but still what is soaking , and what happen's when reflow happens, don't the semiconductors get fried up or something.
    will they sustain at 226C for 20 seconds, i was of an impression that most IC's barring a few power semi's to get cooked at that temperature!
    I myself work for a Semiconductor Nano Fab manufacturer on the mechanical front, but still have surprises and knowledge gain at every corner when Semiconductors are concerned
    Thnx for all the Knowledge base
    Irfan
  9. #249
    Aug 2006
    2758
    Irfan
    They can take more than that for a short time during reflow. I am using a solder paste with 63/37 Sn/Pb ratio, it melts about 185 C. Recommended maximum reflow temp is 230 deg C. Newer solder pastes, with no Lead, require higher reflow temperatures (250 C)
    Soaking time is the time needed for all the board and components to reach an uniform base temperature so the thermal stress on the component's encapsulation and PCB is kept to a minimum when the reflow temperature is reached afterward.
    Some components require an extended temperature treatment in order to control cracking due to absorbed humidity, that is the case for many PLCC, BGA, etc. That process is called Baking period or Baking time (could last for days), and is done prior to the reflow cycle.
  10. #250
    Aug 2006
    2758
    Ready for first set of Tests.
    The PCB is ready for the tests without high voltage, (Low voltage power supplies, logic and translator's tests), after finished with those tests, we attach the power chips and heat-sink in order to begin with the motor driving tests.
    Attached Thumbnails Attached Thumbnails Kreutz-2 Rev3.0i prototype3.jpg   Kreutz-2 Rev3.0i prototype4.jpg
  11. #251
    Aug 2006
    2758
    FYI
    The low voltage tests, logic tests, translators, CPLD and the protection circuits have been tested. I made a few customizations to the Mardus-Kreutz translator's firmware, so this board needs its own firmware Rev B03a, it won't work with the Mardus-Kreutz boards and vice-versa, if somebody installs the wrong firmware, the board in question will simply quit working, and the Error LED will light up, no damage to the boards or chips.
    So far the RF PC input isolation works perfectly fine too.
  12. #252
    1050
    FYI
    Great going Kreutz. Looking forward to the Finale!
  13. #253
    Aug 2006
    2758
    Early Motor tests
    I made a few tests tonight, nothing impressive yet. Using a Keling Technologies' motor model KL23H2100-30-4B (495 oz-in, 3Amp RMS) Tested at 24 V and 35 volts, my settings are still very conservative on the board, I need to tune up the blanking time, and need to replace the heat-sink by the proper one. The current heat-sink is not made for vertical air flow, so it heats up considerably even with only one axis on.
    Early on the thread we discussed the L6203 heating behavior, it really gets hot. The other problem is motor noise, and that one is going to be addressed when tuning the current regulation loop. I want to clarify, that this tuning is neither necessary (after development) nor even an available option for the end user.
    More modifications will be done to the firmware, due to the differences in timing required for switching the bipolar board in slow and fast decays modes (not available on the unipolar board).
    Most of the required logic for Decay mode control is contained into the CPLD, but the translator is the source for the switching signals and micro-step reference signals and some delays added for unipolar dead-band protection will be modified also.
  14. #254
    Aug 2006
    2758
    Test setup photos
    Attached Thumbnails Attached Thumbnails Kreutz-2 Rev3.0i prototype5.jpg   Kreutz-2 Rev3.0i prototype6.jpg   Kreutz-2 Rev3.0i prototype7.jpg
  15. #255
    1050
    HI Kreutz,
    Nice pics, howz the firmware coming up.
    Did those "L's" get heated up so much u had to put 2 fans!
    Great going
    Regards
    Irfan
  16. #256
    Aug 2006
    2758
    HI Kreutz,
    Great going
    Regards
    Irfan
    They really get hot easily, the fins on the heat-sink run horizontally, I placed the two little fans blowing down (used to cool hard-drives) and the thermal problem is temporarily solved, not very efficiently, at least I don't worry too much now while running the tests. So far, I am not impressed at all by the L6203s.
    I haven't had much time to play with the firmware modifications.
    Regards,
    Kreutz.
  17. #257
    Jun 2003
    3312
    I've noticed the same on the L6203's. Major heat dissipation.
    Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
    Vist my websites - http://pminmo.com & http://millpcbs.com
  18. #258
    1050
    Quote Originally Posted by pminmo View Post
    Kreutz
    the L6203's still perform even when hot- dont they! Well Kreutz cant we go the Mosfet way, somehing similar to a GECkO, think you mighthave already given a thought in teh earlier part of the thread. but just looking around.
    Regards
    Irfan
  19. #259
    Aug 2006
    2758
    Kreutz
    Regards
    Irfan
    They do work well, so far. I am limiting my tests under 4 amps peak until I gather enough information to run a few destructive tests... going the discrete mosfet output way won't be an option for this 4 axes board. The beauty of the board's idea was the integrated output simplicity.
  20. #260
    Aug 2006
    2758
    Thanks, Phil, it is comforting to hear I am not the only one having this issue...
  1. BS2+Seperate Bipolar Driver Board
    By frank02189 in forum PIC Programing / Design
    Last Post: 12-13-2006, 01:55 AM
  2. 2.5 amps per phase drive - 2.8 amps per phase bipolar motor ...
    By kochevnik in forum Stepper Motors / Drives
    Last Post: 10-23-2006, 04:48 AM
  3. current per phase, unipolar bipolar
    By Ragnarok in forum Stepper Motors / Drives
    Last Post: 02-23-2006, 04:57 AM
  4. Least part Bipolar board
    By venomx999 in forum Open Source Controller Boards
    Last Post: 12-01-2005, 02:54 AM
  5. 3.5" floppy, 2-phase bipolar stepper.
    By Levitan in forum CNC Machine Related Electronics
    Last Post: 03-21-2005, 05:32 PM
