Just guessing -- you want a cleaner look than using the 90 degree angle brackets they make? I admit that gear can be a bit pricy - with all the screws, and bits, BUT - you have nearly infinate adjustment range in all three axes - and you can use those to help square the rig too. On the other hand, I did some of that "Work-stuff" too so I could mount end fittings for motors, etc - tapped using WD-40.
If it moves and shouldn't - Duct Tape it . If it should and it don't - WD40!
Cheers - Jim
Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it.
