Originally Posted by
bsharp
Ok I have 4 G320’s and three problems.
Problem 1:
Two of them seem like they have no output to the motor. When you power them on the Fault LED comes on and I have 5 volts at encoder power. When I jump encoder 5 volts to err/reset the light goes out and nothing happens. I then can turn the motor and the Fault LED will come on. I suspect that something with the output portion of the drive is blown? Why and how could this happen?
Problem 2:
One of the 4 when powered on will lurch. When main DC power is initially applied to the drive the motor connected to it will lurch an inch or so and stop. When the drive is enabled by supplying 5volts from the encoder supply to err/reset terminal it seams fine. Although if I turn the gain almost all the way down the motor will start to creep in one direction. Why and how could this happen?
The Last problem I have is that it seams like I cannot get any help with these. In the last month or so I have spent nearly 500 dollars on these things and cannot even get a response out of anyone. Let alone any technical help. I am really wishing right now I had never bought them and spent the extra money and bought real drives from somewhere else. If I had the money to do it over you bet your ox I would.
Have you tried calling them? I can tell you that if Mariss know's about your problem he will help. I had problems getting my drives hooked up the first time because I was using a jury rigged power supply. He spent nearly two hours two different days talking me through where to check the voltages and how to wire my rigged ps, which had nothing to do with his drives other than the fact I needed the ps to run them. His support is second to none...period! Call him and ask to speak to him (Mariss).
Mike
No greater love can a man have than this, that he give his life for a friend.
