603,383 active members*
3,273 visitors online*
IndustryArena Forum > OpenSource CNC Design Center > Coding > Archimedean Spiral Algorithm
Results 1 to 7 of 7
    Sep 2007
    18
    Hello there,
    I'm writing a macro which calculates the toolpath for an archimedean spiral. Some controls do have a G code for that others don't.
    My idea is to divide the spiral into circular arcs. For each arc I have to calculate the end point located on the spiral's path. The start point is simply the end point of the former arc. Start and end point are connected by a circular arc.
    The problem is to find the radius for each particular circular arc with the smallest possible deviation to the path of the perfect spiral.
    Does somebody have a formular for that?
    Frank
    Jul 2005
    12177
    If you are writing a macro why don't you simply calculate the spiral there is no reason to approximate it.
    Sep 2007
    18
    Hmm I don't think this is going to work as I think there could be a significant computational load depending on the resolution of the spiral's curvature you want to achieve.
    For example if you want a resolution of lets say 0.001" and the length of the curvature is 1" then you end up with 1000 iterations on a set of calculations.
    Thank you anyway for your thoughts.
    -Frank
    Aug 2007
    47
    I use this method for a general approximation with circle arcs.
    "Given two points and its slopes, find two tangent circle arcs tangents to each point with the minimun radius difference".
    The algebraic steps are a bit hard, the solution written in visual basic is:
    Input values:
    x1,y1,dx1,dy1: Point 1 + Slope
    x2,y2,dx2,dy2: Point 2 + Slope
    Return values:
    xc,yc: Intersection point for circle arcs
    r1: Radius at P1
    r2: Radius at P2
    Function IncenterRR(x1, y1, dx1, dy1, x2, y2, dx2, dy2, xc, yc, r1, r2)
    IncenterRR = 0
    p = Sqr(dx1 ^ 2 + dy1 ^ 2)
    If p < 0.00000001 Then Exit Function
    nx1 = dx1 / p
    ny1 = dy1 / p
    p = Sqr(dx2 ^ 2 + dy2 ^ 2)
    nx2 = dx2 / p
    ny2 = dy2 / p
    xc = x2 - x1
    yc = y2 - y1
    p = nx1 * ny2 - ny1 * nx2 ' Note: if p>0 => G03
    ' if p<0 => G02
    If Abs(p) < 0.00000001 Then Exit Function
    l1 = (nx1 * yc - ny1 * xc) / p ' Distance P1-Po
    If l1 <= 0 Then Exit Function
    l2 = (ny2 * xc - nx2 * yc) / p ' Distance P2-Po
    If l2 <= 0 Then Exit Function
    l3 = Sqr(xc ^ 2 + yc ^ 2) ' Distance P1-P2
    p = l1 + l2 + l3
    q = l2 / p
    xc = x1 + q * (xc + l3 * nx1)
    yc = y1 + q * (yc + l3 * ny1) ' return value xc,yc: Incenter
    p = p / 2 ' Semiperimeter
    l1 = p - l1
    l2 = p - l2
    q = l1 * l2 * (p - l3) / p ' q = Inradius^2
    p = 2 * Sqr(q)
    r1 = (q + l1 ^ 2) / p ' return value r1: Radius @ P1
    r2 = (q + l2 ^ 2) / p ' return value r2: Radius @ P2
    IncenterRR = 1
    End Function
    Applying to Archimedean spiral.
    R = Rini + k*Angle (k=pitch/2PI , Angle in radians)
    X = R*cos(Angle)
    Y = R*sin(Angle)
    dX1 = k*cos(Angle) - Y
    dY1 = k*sin(Angle) + X
    An example in Excel using 45deg steps (calling the VBA function IncenterRR() )
    Pitch = 0.5000
    Rini = 4.0000
    Ang Radius X Y dX dY Xc Yc R1 R2
    0 4.0000 4.0000 0.0000 0.0796 4.0000 3.7236 1.5446 4.0097 4.0513
    45 4.0625 2.8726 2.8726 -2.8164 2.9289 1.5647 3.7830 4.0722 4.1138
    90 4.1250 0.0000 4.1250 -4.1250 0.0796 -1.5925 3.8391 4.1348 4.1763
    135 4.1875 -2.9610 2.9610 -3.0173 -2.9047 -3.8985 1.6125 4.1973 4.2388
    180 4.2500 -4.2500 0.0000 -0.0796 -4.2500 -3.9546 -1.6403 4.2598 4.3013
    225 4.3125 -3.0494 -3.0494 2.9931 -3.1057 -1.6604 -4.0139 4.3223 4.3639
    270 4.3750 0.0000 -4.3750 4.3750 -0.0796 1.6881 -4.0701 4.3848 4.4264
    315 4.4375 3.1378 -3.1378 3.1941 3.0815 4.1294 -1.7082 4.4473 4.4889
    360 4.5000 4.5000 0.0000 0.0796 4.5000 ..................
    And the Gcode looks like:
    G00 X4.0000 Y0.0000
    G03 X3.7236 Y1.5446 R4.0097
    X2.8726 Y2.8726 R4.0513
    X1.5647 Y3.7830 R4.0722
    X0.0000 Y4.1250 R4.1138
    X-1.5925 Y3.8391 R4.1348
    X-2.9610 Y2.9610 R4.1763
    X-3.8985 Y1.6125 R4.1973
    X-4.2500 Y0.0000 R4.2388
    X-3.9546 Y-1.6403 R4.2598
    X-3.0494 Y-3.0494 R4.3013
    X-1.6604 Y-4.0139 R4.3223
    X0.0000 Y-4.3750 R4.3639
    X1.6881 Y-4.0701 R4.3848
    X3.1378 Y-3.1378 R4.4264
    X4.1294 Y-1.7082 R4.4473
    X4.5000 Y0.0000 R4.4889
    Regards.
    Eduardo.
    Dec 2004
    524
    I Dont Know If I Understand...
    Eduardo,
    So -- I think:
    You compute the intersection point of the lines perpendicular to the tangents at the two points of interest. Then you compute the distance from that intersection to each of the points to get the two radii.
    But now we want to approximate the curve between the two points with a circular arc. Ideally, we would like to minimize the maximum error. Since (in principle), we know nothing about the curve between those points, we don't have much to work with.
    There are somethings we can do, though. We can require that the arc goes through both of those points. Since there are an infinity of arcs that do that, it is not a problem. The simple thing to do is to use a straight line, but that misses the point of the exercise.
    It is clear that at each point, we must start at the previous point. We must also end at the next point. If we don't do that, we risk having unbounded error accumulation.
    So, one approach might be to pick a radius between the two that were calculated. Find the center corresponding to it and draw the arc between the two points at that radius. One could pick the larger radius, the smaller radius, the average radius, the geometric mean radius, or something else.
    Assuming that the curve is reasonably well behaved (whatever that means), I would think that the error would be less than the difference between the two radii. Hmmm. Perhaps reasonably well behaved means that the curvature is monotonic between the two points.
    Tell me more. For instance, do you have a quick calculation for the center, given the two points and the radius. (Give me a break, please, it's been almost fifty years since I studied plane geometry.)
    Thanks,
    Ken
    Kenneth Lerman
    55 Main Street
    Newtown, CT 06470
    Sep 2007
    18
    Hi Kenneth,
    I haven't evaluated Eduardo's function yet but your idea corresponds with mine:
    I calculate two points on the path of the spiral. Then I take the radius of each point (i.e. the distance to the spiral's center) and calculate the average radius wich interconnects the two points. This results into an arc with a displaced midpoint to the spiral's center. This approach seems to work as long as you don't start the spiral in the center (i.e. r = 0).
    I'm looking for other possible approaches. I know there's a formular to calculate the radius of curvature. That might be another way to approximate.
    I also found this on the net: http://wotan.liu.edu/docis/dbl/wscgws/2003___PCAOSA.htm
    Here's a MuPad function to calculate the midpoint. No warrenty of course ;-) Maybe somebody knows an easier way?
    /* Calculates the midpoint of a circle through two points (as polar coordinats) on the circumference and the radius. */
    GetMidpoint := proc(r1, a1, r2, a2, r)
    local p1, p2, b, l, a, i, k;
    begin
    p1 := PolarToCartesian(r1, DegreeToRadian(a1));
    p2 := PolarToCartesian(r2, DegreeToRadian(a2));
    /* Bisector of chord. */
    b := sqrt((p1[1] - p2[1])^2 + (p1[2] - p2[2])^2) / 2;
    /* I.e. radius minus segment's height. */
    l := sqrt(r^2 - b^2);
    /* Angle. */
    a := arctan((p1[1] - p2[1]) / (p2[2] - p1[2]));
    /* Do we need to tweak angle? */
    if p2[2] < p1[2] then
    a := a + PI;
    end_if;
    /* What direction counterclockwise or clockwise? */
    if a2 > a1 then
    /* X distance p1 to center */
    i := -(sin(a) * b + cos(a) * l);
    /* Y distance p1 to center */
    k := cos(a) * b - sin(a) * l;
    else
    i := -(sin(a) * b - cos(a) * l);
    k := cos(a) * b + sin(a) * l;
    end_if;
    /* Verify results. */
    assert(is(i^2 + k^2 ~= r^2));
    assert(is((p2[1] - (p1[1] + i))^2 + (p2[2] - (p1[2] + k))^2 ~= r^2));
    /* Return p1, p2 and midpoint as cartesian coordinates. */
    (p1, p2, p1[1] + i, p1[2] + k);
    end_proc;
    Aug 2007
    47
    The image attached show the method, the clue is evaluate the incenter of the triangle P1-P2-P3.
    The amazing property of the incenter is what the circle arcs has minimun radius difference, that mean what the curvature transition is the smoothest.
    Of course, this method is only 'good' when you have the curve equation.
    Having the equation of the curve you may check the deviation.
    For any point of the approximation [x,y] ==> R' = sqrt(x^2+y^2) and Angle' = atan(y/x) + n*PI
    Note: n = 0 for 1st quadrant, 1 for 2nd & 3rd, 2 for 4th & 5th ,,etc
    With a spiral equation R = Ro + k*Angle
    the value dR = R' - Ro - k*Angle' is the radial error of the aproximation
    Unless the steps are greater than 45-60 deg the error is far less than 0.0001
    Given Pini = [x1,y1] , Pend = [x2,y2] , R and sign = 1 if G03 , -1 if G02
    Then
    dx = (x2-x1)/2
    dy = (y2-y1)/2
    p = sign*R/sqrt(dx^2+dy^2)
    h = sign*sqrt(p^2-1)
    I = dx - h*dy
    J = dy + h*dx
    I,J distance from the center to Pini
    Then the circle center
    Ox = x1 + I
    Oy = y1 + J
    Also
    xm = Ox + p*dy
    ym = Oy - p*dx
    xm,ym Arc middle point
    Regards.
    Eduardo.
  1. Algorithm?
    By CNCgr in forum OpenSource Software
    Last Post: 12-08-2009, 12:23 AM
  2. Algorithm for G02 / G03 coding
    By jemmyell in forum Coding
    Last Post: 08-06-2009, 11:58 PM
  3. XY positioning algorithm needed
    By Tracid in forum PIC Programing / Design
    Last Post: 11-28-2006, 05:26 PM
  4. Need Help With Circular Pocketing Algorithm
    By lerman in forum G-Code Programing
    Last Post: 11-20-2006, 11:41 PM
  5. Blending algorithm of EMC2
    By Hebert in forum LinuxCNC (formerly EMC2)
    Last Post: 10-21-2006, 04:22 PM
