588,578 active members*
12,436 visitors online*
Results 1 to 16 of 16
    Jan 2007
    525
    Tracing Logo's in CAD
    I want to take my company's logo and manually re-create it in a CAD program (it's mostly straight lines - so shouldn't be too difficult). I've done this type of work before in Pagemaker when I've needed to vectorize jpg's.
    Is there a common way to do this? Is there a way I can import the JPG logo in order to "trace" it?
    Thanks!
    May 2005
    1810
    What CAD package are you using?
    Scott
    Consistency is a good thing....unless you're consistently an idiot.
    Jan 2007
    525
    None yet (well, have been working on Alibre Express and am considering purchasing BobCAD)...
    Tormach PCNC 1100, SprutCAM, Alibre CAD
    322
    Quote Originally Posted by tikka308 View Post
    Use CorelDRAW. Export with the DXFTool and cut with SheetCAM.
    -James
    James Leonard - www.DragonCNC.com - www.LeonardCNCSoftware.com - www.CorelDRAWCadCam.com - www.LeonardMusicalInstruments.com
    May 2007
    10
    Rhino will take bitmap images that can be traced over.
    Jan 2007
    525
    I don't own CorelDraw (nor do I want to pay for more software right now, unless necessary). I do own Illustrator and was able to draw something and export as a DXF into Sheetcam with no problems.
    However, I'll normally want to include this file within a part - so once you export the DXF from Illustrator or Corel, can you then import it into a CAD software and resize it as needed?
    May 2004
    82
    "I've done this type of work before in Pagemaker when I've needed to vectorize jpg's. "
    If pagemaker can export DXF you should be god. Just import in your CAM
    Bent
    Sep 2006
    104
    Inkscape is free and can export to DXF
    Dec 2003
    24221
    This is one way if you have a trace package or similar to Core OCR-Trace.
    http://www.torchmate.com/assistance/convert.htm
    Al.
    Albert E.
    Aug 2006
    493
    Hey guys. I use a program called pattern wizzard. Its a staind glass pattern software. I find it way easyer to trace any thing with than any of the other software ive used. then I export the pattern to wintopo to vectorize it to dfx. pattern wizard is free for 40 hrs of using time. It only takes a few minutes to create a design so the 40 hrs last for a long time, then its like $60.00 I think to buy. try it and tell me what you think. www.sgdesigns.com .
    Graham
    Jun 2003
    2103
    .308, you know I'm hustling.....but :banana: if you will send me, or post a jpg, of the logo and the size you want it, I will trace it in Rhino, and keep track of how long it took me. The new version 4 has a command called pictureframe that allows this to be done pretty quickly.
    Mike
    No greater love can a man have than this, that he give his life for a friend.
    Quote Originally Posted by CountZero View Post
    inkscape works great for this type of stuff
    May 2006
    1469
    If you already have Illustrator, it has a very capable tracing feature. At least the version I have does.
    You can also scale the resultant vectors to any size you want. All within Illustrator. Then export as a DXF.
    Greg
    Nov 2006
    382
    I have done this alot with AutoCad. You can import a scanned immage with it. trace arround it and then iges it out to a machining software like MasterCam, Bobcad, or what ever you have and it will work great. You will need to scale it to make it right in AutoCad but that is easy there. If you want send me a jpg and I will quote it for you.
    Jan 2007
    525
    Turmite - better yet, how about I try it first on my rhino demo. Pictureframe is the command you say? Would I first import the image in order to view it for tracing?
    Jun 2003
    2103
    Hey tikka, yes pictureframe. If you want to call me around noon central time, I can talk you through it.
    Mike
  1. Tracing?
    By Joe Petro in forum Uncategorised CAM Discussion
    Last Post: 11-03-2007, 01:19 AM
  2. DWG/DXF Car Logo's
    By Gujustud in forum Community Club House
    Last Post: 08-24-2006, 06:34 PM
  3. Tracing eye and MACH 3
    By DSL PWR in forum Mach Plasma / Laser
    Last Post: 08-17-2006, 02:37 PM
  4. Tracing a picture in CAD
    By DennisCNC in forum Uncategorised CAM Discussion
    Last Post: 05-15-2006, 11:32 AM
  5. Tracing Carboard Patterns
    By cncmitch in forum Uncategorised CAM Discussion
    Last Post: 03-30-2005, 11:12 PM
