587,614 active members*
3,654 visitors online*
Results 1 to 9 of 9
    Jun 2007
    6
    A-axis on bed mill
    I have the feeling that the turning direction of my A-axis is swiched, please take a look at the image and tell me; if I push the + botton on the control should the table turn as the arrow shows?
    Oct 2006
    669
    I'm pretty sure it should turn the opposite direction of the arrow you've drawn.
    May 2007
    95
    Well, in physics, positive rotation is CCW when looking from the positive direction of the axis that the rotation is about. However, I think if anything is it should be a personal preference.
    Though, if you are going to be CNCing, I suppose it would be best to find what is most commonly used in milling / CNCing.
    Jun 2007
    6
    Ok, let me know from you out there; what is the setup on your machine; CW looking from the positive direction of the axis (like on my machine, see image in 1st post) or CCW looking from the positive direction of the axis. Help me convince my service guy, my thumb isn't enough.
    Thumb pointing in positive direction of the axis
    Fingers ponting in positive direction of the axis rotation
    May 2007
    95
    Heh, that is the technique I was thinking of. The "Right Hand Rule."
    If you wrap your fingers around the axis, with your thumb pointing in the positive direction (Id assume comine out from the center of the table), that is the positive direction.
    With that said, if it were me, Id say the direction indicated is the positive direction, unless there is some metric I am not thinking about.
    Oct 2007
    37
    The A axis is kinda iffy for which direction to go. I work with some mazaks with 4th axis we have 2 machines that have the 4th axis mounted on the left and one with it mounted on the right so it turns in reverse.
    Jun 2007
    6
    Quote Originally Posted by vigilante212 View Post
    Ok, but still, if you look from the possitive end of the x-axis it (in my opinion) must be the same, no matter if the round table facing in the X-axis possitive or negative direction. Does that theory fit with your Mazaks? If it does, is the arrow (in the image in the first post) poiting in the + or - way, on your machines?
    Nov 2007
    479
    0 degrees being at 3 o'clock position and 90 degrees at 12 o'clock position, therefore it would have to rotate cw to go in positive direction right?
    Dec 2006
    84
    Your axis is rotating correctly. Direction is determined looking through the back of the motor.
    Looking at the end of the motor when you press the + button the motor turns clockwise from this perspective.
    It is no different than a horizontal mill spindle. Facing the spindle an M3 command CW, would appear to be CCW, but looking at it from the perspective of the cutter and the motor, it would be clockwise.
  1. the Difference of 2-Axis and 3-Axis of Vertical Mill Machine
    By begacon in forum Knee Vertical Mills
    Last Post: 07-30-2009, 12:31 PM
  2. Z-axis mill drive
    By Nzoldun in forum Benchtop Machines
    Last Post: 08-23-2007, 07:51 PM
  3. Could this be done on a standard 3-axis mill?
    By Fox Speedshop in forum Uncategorised MetalWorking Machines
    Last Post: 02-09-2007, 02:37 PM
  4. Z Axis For Mill
    By heilcnc in forum Benchtop Machines
    Last Post: 04-08-2005, 02:49 AM
