588,457 active members*
5,163 visitors online*
Thread: serial port
Results 1 to 10 of 10
    Apr 2007
    641
    serial port
    Now that I have the frame at paint shop, I have to buy the laptop or PC for the cnc, but i have a problem, the conection to pc is by serial port, new pc's dont have it, someone tell me to get a converter card to usb, anyone knows if it will work?
    Jan 2006
    2985
    Yes it should work. You can, I believe still buy PCI based serial ports, which may be cheaper than the USB option.
    Either way I'm sure one of these will work for you.
    Matt
    Feb 2006
    1260
    Quote Originally Posted by lamicron View Post
    I've read a lot of stuff that indicates a usb to serial for cnc imput output isn't really the way to go. For that matter neither is a laptop.
    Are you sure it's serial you need? My setup uses 2 parallel ports.
    Some say it will work others say not. If I tried it it would be a big fat NOT.
    I know I tried using a desktop Vista. I was making progress. but it was driving me crazy. So I went with a P4 XP Pro. Everything has worked with it great.
    If it works.....Don't fix it!
    Apr 2007
    641
    Hi Millman, I have the keling 4030 package, this card uses the same connection for the old printers, is that serial or parallel port? Keling sells a card to convert to usb,
    I'm also using XP,
    Luis
    Feb 2006
    1260
    I'm also using XP,
    Luis
    I looked at the Keling site It's looks like a parallel connection.
    I really have no idea if a ad on PCI slot Parallel card would be any better than the one that is usually integrated to the motherboard.
    Most of the ad ons claim to be about 3 times faster than the integrated ones.
    You might post that question somewhere here on the Zone.
    My set up uses 2 parallel ports. I think thats because of the THC1000 though.
    Just a thought.
    Jul 2006
    39
    just a thought but why buy a new desktop. buy used that already has a serial port. ebay has several sellers that refurb end of lease turn in's. just a thought.
    Apr 2007
    641
    Yes, I used an old one, the problem is that I make the machines to sale, then every`part should be new.
    Jul 2006
    39
    this might be cruel but u can get an HP desktop at staples for 299.00us$ i just bought one for a bridgeport and it works just fine. i did have to spend another 12 bucks for a 3.5 floppy ext drive.
    good luck
    Apr 2007
    641
    Yes, >I think i have to go for that kind of solution, thanks
    Luis
    Jun 2007
    3735
    Talking I think you need a second hand licence!
    (LOL):devious:
  1. EMC2 Serial Port?
    By willhrt in forum LinuxCNC (formerly EMC2)
    Last Post: 02-12-2012, 07:55 PM
  2. Serial Port Issues
    By Egar Twins in forum DNC Problems and Solutions
    Last Post: 08-01-2011, 07:25 AM
  3. serial port controller
    By eloid in forum Servo Motors / Drives
    Last Post: 03-10-2007, 04:49 AM
  4. USB to serial port
    By stampman in forum DNC Problems and Solutions
    Last Post: 12-30-2006, 08:17 PM
  5. VK45 serial port
    By TJ in CT in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 11-07-2005, 04:52 PM
