587,118 active members*
2,946 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Axis bypass procedure for diagnosis in 10M
Results 1 to 5 of 5
    Sep 2006
    15
    Question Axis bypass procedure for diagnosis in 10M
    Z axis is having problem, for diagnosis purpose we want to by pass the z axis. It 'll be helpful if anybody can tell the axis bypass procedure for 10M(using parameter or connector).
    Dummy Plugs
    Try making up dummy plugs
    Attached Files Attached Files
    Sep 2006
    15
    Thank you 'cncdiag'..any parameter has to be changed (i.e. P1023/P2009)?
    Nov 2003
    98
    Quote Originally Posted by cncdiag View Post
    Great share,
    thanks
    Bob
    May 2005
    109
  1. Servo Error Bypass?
    By Radius in forum Milltronics
    Last Post: 12-04-2007, 07:50 PM
  2. 3 phase bypass question
    By Chris64 in forum MetalWork Discussion
    Last Post: 09-09-2006, 05:07 PM
  3. Question on a procedure
    By gv71 in forum OneCNC
    Last Post: 06-14-2006, 01:51 AM
  4. How do i bypass 4000 rpm on haas TM2
    By Craigmack in forum Haas Mills
    Last Post: 08-06-2005, 11:34 PM
