588,323 active members*
5,274 visitors online*
    6855
    Silicon or copper?
    I've been using silicon reflective mirrors for my C02 laser and I'm considering going to copper, the reflectiing is slightly better but is their any special care to maintain the mirrors will I see a big improvement to total power out-put?
    Oct 2007
    240
    In order of reflectivity (high to low): AR-coated copper, coated gold, and dielectric enhanced silver on silicon. If he mirror is properly coated, there should be no maintenance required other than occasionally wiping the face gently with a cleaning cloth.
    Hi-TecDesigns.com -- Automotive Lighting Systems
    Nov 2007
    23
    dragging a acetone lens tissue across them is typical cleaning. When they get alittle heavier smog, a good copper polish (like brasso) gentle rubbed to break the haze then acetone cleaning. A protected bellow cover over the beam path with a positive pressure blower guards against smoke and contaminates. It also extends mirror maintenance intervals and life. Watch for sweating in high humidity.
    Mar 2007
    51
    Talking
    Paul, at your power levels you shouldn't see any performance difference between the different mirror types. I would just go with whatevers CHEAPEST.
    Laser.Tech
    If it's already been done, then it ain't NO FUN!
  1. Nickel Silicon-Carbide (Nikasil)
    By crayner in forum Material Machining Solutions
    Last Post: 01-20-2008, 05:35 AM
  2. Silicon Sealant work with coolant??
    By Rodm1954 in forum Benchtop Machines
    Last Post: 11-03-2007, 09:15 AM
  3. Silicon Nitride Milling Inserts?
    By ajl6549 in forum MetalWork Discussion
    Last Post: 02-12-2007, 03:23 PM
  4. Machinist looking for work in Silicon Valley
    By Grinding Guy in forum Employment Opportunity
    Last Post: 10-30-2006, 12:07 AM
  5. Silicon Bronze
    By drakesis in forum Casting Metals
    Last Post: 02-24-2006, 12:18 AM
