587,999 active members*
4,848 visitors online*
Thread: mits mv65c
Results 1 to 6 of 6
    Aug 2007
    31
    mits mv65c
    meldas 300 control, having problem with running a G83 drilling cycle in X with a right angle head, tryed changing plane, book says G19, no luck? any ideas
    Jul 2006
    65
    Try using a G87 instead of a G83...your plane shouldn't matter if your only moving one axis..G87 is the same as a G83 except for the X axis instead of Z....I've never worked with the 300 control but it works on other Mits Meldas controls...
    Aug 2007
    31
    This is a vertical mill, the G87 is a back bore cycle, I have seen what your talking about on a lathe with live tooling, thanks for the input, any other Ideas ?
    Jul 2006
    65
    sorry for the confusion....not familiar with the machine but, you could always write a Drill Pecking Macro...for example..
    G65 P8888 U.100 Q.03 R.01 F.001 (instead of G83 line in prg)
    O8888(sub Prg)
    #7=#17
    #8=0
    #3=#17
    #2=0
    IF[#3GE#21]GOTO10
    WHILE[#7LE#21]DO1
    G0U#8
    G1U#3F#9
    G0U-#7
    #2=[#2+#17]
    #8=[#2-#18]
    #3=[#17+#18]
    #7=[#3+#8]
    END1
    IF[#2EQ#21]GOTO99
    N10
    #3=[#21-#8]
    G0U#8
    G1U#3F#9
    G0U-[#3+#8]
    N99
    M99
    I'm sure there is a shorter way to write it..but something like this should work..at least drilling in the X(U) + direction...it will probably need to change a little if your drilling in the X(U) - direction I didn't look into it enough to know...
    (note: this moves incrementally (U) )
    Jul 2006
    65
    this prg should work in the pos or neg direction....
    G65 P8888 U-.100 Q-.03 R-.01 F.001 (for drilling in U (-) direction)
    G65 P8888 U.100 Q.03 R.01 F.001 (for drilling in U (+) direction)
    O8888(sub Prg)
    #7=#17
    #8=0
    #3=#17
    #2=0
    IF[[ABS[#3]]GE[ABS[#21]]]GOTO10
    WHILE[[ABS[#7]]LE[ABS[#21]]]DO1
    G0U#8
    G1U#3F#9
    G0U-#7
    #2=[#2+#17]
    #8=[#2-#18]
    #3=[#17+#18]
    #7=[#3+#8]
    END1
    IF[[ABS[#2]]EQ[ABS[#21]]]GOTO99
    N10
    #3=[#21-#8]
    G0U#8
    G1U#3F#9
    G0U-[#3+#8]
    N99
    Aug 2007
    31
    No macro option (sucks) I ended up using a poor mans G83 (incramentel sub) and and nesting it with another sub so I can call it up when I need it , it works ,but kinda old school, thanks for all the input
  1. fanuc/mits Macro
    By positiverake1 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 10-29-2007, 01:08 PM
  2. Mits FX2 Wire EDM Problem.
    By weblogictech in forum Waterjet General Topics
    Last Post: 12-16-2006, 07:28 AM
  3. mits sinker edm
    By mmachining in forum Waterjet General Topics
    Last Post: 06-19-2006, 08:31 PM
  4. ex8 mits sinker question!
    By KANNON123 in forum Waterjet General Topics
    Last Post: 01-28-2005, 03:02 PM
  5. Mits Vs. Charmilles
    By GOOCH in forum Waterjet General Topics
    Last Post: 08-27-2004, 04:57 PM
