588,217 active members*
4,307 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Front panel milling dimensions
Results 1 to 7 of 7
    Oct 2006
    64
    I've been working on this electronic project and I created a front panel using Front Panel Express.
    Their work is great, I really like the result.
    My measurements are spot on when it comes to lining up the buttons to the holes. But it seems the panel's holes are exactly the same size as the buttons which go in them. So I can't fit the buttons into the holes unless I seriously file out the holes.
    I think I just need to enlarge the hole dimensions and resubmit the job, but I'm not sure how much larger to make them.
    Any recommendations?
    Jan 2006
    2985
    Measure it!
    Get some calipers and see how big your switches are. Make the holes .005-.010 bigger.
    Matt
    Oct 2006
    64
    They are exactly .500 and my holes are exactly .500 as well.
    May 2005
    1810
    If the buttons are secured by a threaded post I would open them up .010-.015. If they are pop in and retained by spring tabs, I would suggest filing to fit.
    The spring tab mounted switch manufacturer's recommended dimensions usually are a good starting point but I have found that they are usually a little too sloppy for my taste. You don't want the fit too tight as if may interfere with the operation of the switch or button.
    Scott
    Consistency is a good thing....unless you're consistently an idiot.
    Oct 2005
    1237
    Looking at your top plate, the corner radiuses are larger than the corners of the buttons. When you file the openings, you will need to pay attention to these areas. The same size openings as the buttons issue isn't that bad. Just a little will go a long wayonce your corners are fixed.
    May 2005
    1810
    What's with the "Kill" button? Sounds kinda dangerous....
    That's a good looking panel, BTW.
    Scott
    Oct 2006
    64
    Kill bypasses the whole device. Removes it from the chain. Kills it.
    Its a midi controlled audio matrix switch.
  1. drawer front inlays
    By mike hide in forum WoodWorking Topics
    Last Post: 01-11-2008, 06:02 PM
  2. End of Program - Front and Center
    By donl517 in forum Fadal
    Last Post: 10-10-2007, 02:40 PM
  3. SX3 Head front panel Caution!
    By keen in forum Syil Products
    Last Post: 04-11-2007, 04:43 AM
  4. Can I add more LED's to CPU front panel?
    By Fluxion in forum CNC Machine Related Electronics
    Last Post: 01-30-2007, 05:10 AM
