588,585 active members*
12,137 visitors online*
Page 1 of 2 12
Results 1 to 20 of 21
    New guy question
    Hi All,
    I have a Sharp 2412 VMC with a Fanuc oi computer. I believe there are some canned cycles however the documentation is nasty at best. I am still very new to g-coding with about 6 months under my belt.
    I want to mill a circle pocket (1.5” dia) and a rectangular pocket (2”x3”), both with the origin at 0,0, (two different parts) and using a 1/2” end mill. Both will be 0.025” in depth.
    Can anyone advise me if there is a simple way to achieve this? Thanks very much in advance!
    Larry
    PS I also posted this in the G-Code section
    Aug 2005
    578
    This is the 1.5 dia pocket
    The origin is the center
    O0000 (T)
    (MASTERCAM - X)
    (MCX FILE - T)
    (POST - %MCAMDIR%MILL\POSTS\MPMASTER.PST)
    (MATERIAL - ALUMINUM INCH - 2024)
    (PROGRAM - T.NC)
    (DATE - JAN-09-2008)
    (TIME - 6:38 AM)
    (POST DEV - IN-HOUSE SOLUTIONS)
    (T1 - 1/2 FLAT ENDMILL - H1 - D1 - D0.5000")
    G00 G17 G20 G40 G80 G90
    T1 M06 ( 1/2 FLAT ENDMILL)
    (MAX - Z.25)
    (MIN - Z-.025)
    G00 G90 G54 X-.2229 Y.1133 S10000 M03
    G43 H1 Z.25
    G8 P1
    Z.1
    G94 G01 Z.01 F25.
    G02 X.25 Y0. Z-.025 I.2229 J-.1133 F50.
    G01 X.0469
    G03 X-.2344 I-.1406 J0.
    X.4219 I.3281 J0.
    X.0906 Y.4816 I-.5156 J0.
    X-.0906 Y-.4816 I-.0906 J-.4816
    X.49 Y0. I.0906 J.4816
    X.0906 Y.4816 I-.49 J0.
    G01 Z.075 F385.
    G00 Z.25
    X-.375 Y.1768
    Z.1
    G01 Z-.025 F25.
    G41 D1 X-.4634 Y.0884 F50.
    G03 X-.5 Y0. I.0884 J-.0884
    X.5 I.5 J0.
    X-.5 I-.5 J0.
    X-.4996 Y-.02 I.5 J0.
    X-.4595 Y-.1069 I.1249 J.005
    G01 G40 X-.3676 Y-.1916
    Z.075 F385.
    G00 Z.25
    G8 P0
    M05
    G91 G28 Z0.
    G28 Y0.
    G90
    M30
    And this is the rectangular pocket. 2.0 in X and 3.0 in Y
    Origin at the top left
    O0000 (T)
    (MASTERCAM - X)
    (MCX FILE - T)
    (PROGRAM - T.NC)
    (TIME - 6:42 AM)
    (MAX - Z.25)
    (MIN - Z-.025)
    G00 G90 G54 X1.3971 Y-1.7222 S10000 M03
    G43 H1 Z.25
    g8 p1
    Z.1
    G94 G01 Z.01 F25.
    G02 X.8514 Y-2.0149 Z-.025 I-.4584 J.1997 F50.
    G01 X.8225 Y-2.1775
    X1.1775
    X1.2507 Y-2.2507
    X1.1775 Y-2.1775
    Y-.8225
    X1.2507 Y-.7493
    X1.1775 Y-.8225
    X.8225
    X.7493 Y-.7493
    X.8225 Y-.8225
    Y-2.1775
    X.7493 Y-2.2507
    X.635 Y-2.365
    X1.365
    X1.4382 Y-2.4382
    X1.365 Y-2.365
    Y-.635
    X1.4382 Y-.5618
    X1.365 Y-.635
    X.635
    X.5618 Y-.5618
    X.635 Y-.635
    Y-2.365
    X.5618 Y-2.4382
    X.26 Y-2.74
    X1.74
    Y-.26
    X.26
    Y-2.74
    Z.075 F385.
    G00 Z.25
    X1.3536 Y-.5
    Z.1
    G01 Z-.025 F25.
    G41 D1 X1.1768 Y-.3232 F50.
    G03 X1. Y-.25 I-.1768 J-.1768
    G01 X.25
    Y-2.75
    X1.75
    Y-.25
    X1.
    X.98
    G03 X.8032 Y-.3232 I0. J-.25
    G01 G40 X.6264 Y-.5
    Z.075 F385.
    G00 Z.25
    g8 p0
    M05
    G91 G28 Z0.
    G28 Y0.
    G90
    M30
    As you can see, I turn on HSM with G8's so if you don't have that option, delete them
    New guy question
    Hi PBMW,
    Thanks so much. For the most part I follow however I am unfamiliar with the code G8 P1 and G8 P0. I looked up the G8 code in the manual and it says
    "advanced preview control”. Can you shed some light on what this code does?
    Again, my thanks!
    Larry
    Jun 2005
    232
    Hello Larry after reading you post ,I went to the manual guide oi
    in the sharp mini mill 2414 its remindes me of a conversational control it just asks alot of questions what tool number spindle speed coolant on or off ,tool ofset ect, then you can choose from a list of about 40 caned cycles to use .Drill cycles pocketing ect.
    But after anserwing all the questions it spits out the program
    . But the program is not in the corect order it will turn the spindle on then do a tool change.I can etit the program but then i get an alarm.This would be a very valuable and speed up programing
    on some parts, But i just can't get it to work. Your not alone
    Tim
    Aug 2005
    578
    The G8's are controling the look ahead function of the control if you have that option. G8 P1 turns it on and G8 P0 turns it off. This option will control the feedrate so as to more closely follow the part geometry and to reduce the "Stuttering" that happens when you go too fast.
    G5.1 also controls a slightly different form of contouring known as AI NANO
    If you don't have that option...just delete them.
    Thanks guys!
    This place is great.
    Larry
    Sep 2007
    25
    PBMW YOU CAN PROGRAM THAT MANUALLY CAN'T YOU?
    A simple way to program a hole.
    1.500 dia hole
    .500 dia em
    T1M6(1/2 EM)
    G0G90G54X0Y0
    M3S5000
    G43Z1.H1
    M8
    G1Z.1F50.
    G1Z-.025F10.
    G91G01X-.5F8.
    G03I.5
    G1X.5F50.
    G90
    G0Z2.
    M9
    G0G91G28Z0Y0
    M5
    M30
    When posting you can also use R's instead of I & J codes.
    You should edit your post.
    I worked at a place once where they actually had the address of the place in their programs.
    Aug 2005
    578
    Of course I can program it by hand. What's the point?
    Why should I edit my post?
    Does it bother you that much?
    I's and J's are in fact a little more accurate.
    How come you got no comp in there to control the size?
    Jeez....tough room.
    Sep 2007
    25
    Of course I AND J codes are better with cad cams, but R'S are easyer to program manually.
    The guy is a novice why don't you give him something to use forever not a computer generated program.
    P.S. You have 10 lines at the top of the program you can delete, lol
    I BET YOU LEARNED CAD CAM THEN STARTED WORKING AT A MACHINE SHOP.
    Feb 2007
    664
    Quote Originally Posted by MASTERCAMMASTER View Post
    use "I" and "J" when the end points are more important
    use "R" or "P" when the radius is more important
    the faster your feed rate the less accurate the machine will be so you need to tell it what's important
    Aug 2005
    578
    Are you joking?
    I've OWNED my shop since 1982
    So what if there's 10 lines that can be deleted.
    Know what, I catch someone programming a machine at the control instead of running it like I pay them to do they're out the door.
    There's a much larger picture here...the machine has to run to make a dime. You don't use a hunnert grand CNC as a calculator if you have a lick of sense
    You OBVIOUSLY don't own a machine do you.
    Sep 2007
    25
    Quote Originally Posted by PBMW View Post
    Are you joking?
    Today I made a program right on the machine 3 whole tools.
    Spot
    Drill
    Ream
    I happen to like perfect posts.
    Quality is way more important than time, maybe thats because Lockheed Missle & Space, and Northrop Grumman both in Sunnyvale, Ca. pay so well I don't have to hurry.
    Your computer must be closer to the machine than mine.
    E-MAIL me at [email protected] and I can e-mail you a video of my shop. Here in silicon valley there is NEVER snow and you don't have to worry about freezing to death. Oh I forgot to say eh?
    Land here is 1 million an acre how much is it where you live?
    Dec 2007
    5
    Hey, man you have 24 posts! Be warned makes you look like a Troll, when you judge ppl who been here for a long time! That's why I don't post, unless I have something ei: funny or informative to relate!
    Sep 2007
    25
    Quote Originally Posted by evogun View Post
    Wow, 24 posts is alot.
    I played golf today, thats funny for a Canadian in winter isn't it eh?
    Dec 2007
    5
    No, the funny part is that I'm on Vancouver Island and we can play golf today as well. Little you know about your neighbors to the north, for a guy who claims to work for a rocket company.
    Thanks Eh!
    2932
    Larry...
    Notice how just after you said "Thanks guys." and "This place is great!" what had been a helpful thread turned sour?
    MASTERCAMMASTER apparently thinks PBMW's shop is somwhere in the frozen tundra, and he's obviously none too fond of our friends north of the border. BTW, PBMW's shop is NOT in Canada.
    While you may not have to worry about snow and freezing to death in the Silicon Valley, there is the daily four-hour commute getting from your million-dollar-an-acre home to your shop, the occasional freeway collapse, and all the smog you can chew... Eh? Lucky you.
    Oh, and MASTERCAMMASTER: your program has 3 consecutive blocks with G1 (or G01). A terrible waste of memory.
    Hey All,
    By the way I am up in the Sierra and I do worry about snow and freezing to death. LOL
    Sorry that things turned sour however I still appreciate the help.
    How bout those Dodgers
    Larry
    2932
    My bad. MASTERCAMMASTER wasn't referring to PBMW's shop being in Canada... he was referring to EVOGUN.
    Oct 2006
    25
    If that is not JB he must be car pooling with him. PBMW is a terrific resource on these Sharp machines - he has pulled my bacon out of the fire a couple of times.
    2932
    You know, Mickey, when I first read his post, I immediately thought of JB. It occurs to me that no one's ever seen the two of them together. Hmmm...
Page 1 of 2 12
