588,484 active members*
5,348 visitors online*
Results 1 to 11 of 11
    Aug 2005
    578
    x axis bearing truck
    Has anyone developed a three point contact bearing truck that is 12,4,8 oclock position. using skate bearings of course
    Nov 2007
    483
    You should check Joes 2006 design for his z axis. I believe that's what you are looking for.
    Aug 2005
    578
    yepper
    yeah but was looking more at the sosylva type setup.....with 3 bearings contacting.
    Bob
    Aug 2004
    3215
    my z-axis does have three bearings, but is only for open rail.
    joe
    May 2004
    82
    I made this one. There is not 120 degrees between bearings only 110 as i leave room at the bottom for support of the rail. The slots is so i can mill this in 1 setup. Overenginered but hey every 14 min a new one drops out of the mill.
    Bent
    Attached Files Attached Files
    Aug 2005
    578
    Joe
    I looked at your drawings but must have missed the 3 point truck . all I saw was an angle with the skate bearings at right angles. I will look closer.
    Bent
    Your truck is more like what I was looking for but it is machine intensive. I do have a friend that has a CNC mill. would you share your design or are you producing it for sale?
    I have seen one on buildyouridea.com under the casting and cnc links. Pretty nice but would have to set up a casting setup.....more stuff to consider.
    Bob
    Aug 2005
    578
    bearing truck
    Also Just to shed some light... I have just started a thread called scrapyard cnc. Just so you can see what materials I am using to put this together. I have 2 inch emt conduit. (had it already) and the bed is the side panel out of Home depot steel rack. I am supporting the rails with conduit hanger tee slot.
    but more of this in the thread.
    Bob
    May 2004
    82
    Here you go. I didnt draw this myself just designed it. I only have it as a solidworks part. It needs 3 bearings OD 25MM ID 10MM and it fits a rail OD 25MM.
    Remember to change the zip extension to sldprt
    Bent
    Aug 2005
    578
    thanx
    What version did you save this in... I have 2006
    May 2004
    82
    As i said i didnt draw it but it saved in version 2007
    Bent
    Aug 2005
    578
    thanks
    Bent
    Thank you for your great post. I downloaded the eviewer from solidworks and took a look...Great design. I am going to create a set and give it a try. Thanks again.
    Bob
  1. MV Jr. Z Axis thrust bearing replacement
    By TWyatt9 in forum Mori Seiki lathes
    Last Post: 11-26-2007, 01:19 PM
  2. X-Y-Z Axis Bearing Support - Dimensions?
    By joecomunale in forum Joes CNC Model 2006
    Last Post: 05-17-2007, 11:49 PM
  3. new bearing design for x-axis
    By myinisjap in forum Linear and Rotary Motion
    Last Post: 02-02-2007, 01:55 PM
  4. What is 4th or 5th axis bearing type ?
    By bigg in forum Mechanical Calculations/Engineering Design
    Last Post: 10-03-2006, 07:54 PM
  5. 4020 Z axis bearing carrier.
    By little bubba in forum Fadal
    Last Post: 02-03-2006, 04:04 PM
