587,818 active members*
3,069 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > Gecko Motor Voltage?
Results 1 to 5 of 5
    Jun 2004
    38
    Question Gecko Motor Voltage?
    Am I right in my understanding that it doesn't matter if the supply voltage exceeds the maximum servo motor voltage, as long as it's under the 80V Gecko maximum as the G320/G340/G380 act like a switched power supply so the motor will only ever see the appropriate voltage level, as long as they are tuned correctly?
    I've got a 65V DC PSU but my motors are rated at 48V max
    35538
    I don't think so. I think you need a power supply no larger than the servos rated voltage.
    37
    From what I have read on servos. You need to stay within +- 5VDC of the rated voltage. If your power supply has a full bridge rectifier, you may be able to change it to a half bridge and get the voltage you need.
    Feb 2006
    196
    Call gecko, they will tell you what you need ask for Mariss or Marcus.
    When all is said and done, more is said than done.
    Dec 2003
    24220
    Many drive manufacturers specify DC supply 110~120% of motor voltage, there is no direct line between PS and motor, there is a drive in between, higher than specified peak voltage perse on a motor does not damage it, unless allowed to overspeed, RPM is is relative to voltage, so as long as the drive controls both the average voltage and max current level, usually no harm is done.
    Here is an exellent article on PS, Drive and motor selection.
    http://electronicdesign.com/Articles...ArticleID=7635
    Al.
    Albert E.
  1. Is Gecko 320 tuning supply voltage dependant?
    By digits in forum Gecko Drives
    Last Post: 06-19-2007, 12:59 PM
  2. motor voltage
    By planescott in forum Stepper Motors / Drives
    Last Post: 12-29-2005, 04:28 AM
  3. Transformer voltage seems too high for Gecko
    By bgolash in forum CNC Machine Related Electronics
    Last Post: 12-25-2004, 05:35 PM
  4. Gecko Voltage Question
    By ninewgt in forum Gecko Drives
    Last Post: 08-01-2004, 07:31 PM
  5. servo motor voltage?
    By tpworks in forum Gecko Drives
    Last Post: 04-17-2004, 08:34 AM
