Without going into the fine details about your application, I have come up with the following:
4 x 20mm Profile Rail
- Carriage: Two per rail
- Length: 1900mm £612.12
3 x ZPSF2005 (Ballscrew)
- Mounting Block (Fixed End): BK-15
- Machining: None
- Ball Nut: Single (ZPSF)
- Length: 1900mm
- Mounting Block (Floating End): BF-15 £344.25
1 x ZPSF1605 (Ballscrew)
- Length: 200mm
- Machining: None
- Mounting Block (Fixed End): BK-12
- Mounting Block (Floating End): BF-12 £52.64
2 xSFC16 Precision Round Rail (16mm)
- Carriage: Two
- Length: 300mm £22.28
4 x SK Mounting for SFC
- Model: SK16 (for 16mm rail) £4.24
This works out to be
Sub-Total: £1,035.53
Shipping: £0.00 (Free)
VAT (17.5%): £181.22
Total: £1,216.75
This is for three axis Ball screws and bearings, mounting blocks, and assuming you will do the machining on the ball screws for the mounting blocks?
Originally Posted by
rgillard
What would be the approximate cost of ball screws and linear guides for a 5ft X 5 ft machine. I would like to have a screw on both sides of the X axis, one for the y axis and a short one for the z axis. Ball Park Figure? I was under the impression that these linear guides were cheaper than ballscrews. I dont think I will ever need to cut anything more than half a sheet of steel which is 4 ft by 4 ft. Building a smaller table means that it wont take up too much of my precious shed floor.
Ronan
Zapp Automation Ltd
www.slidesandballscrews.com
