588,208 active members*
4,504 visitors online*
IndustryArena Forum > Community Club House > Steppers stall at low speed
Results 1 to 5 of 5
    Jan 2008
    38
    I aquired a home-brew 2 axis CNC about two weeks ago. It's taken me
    some time to research steppers and drivers etc and get this thing
    running. Finally after about 8 hours of sending bit sequences to the
    interface I finally got it figured out.
    It come with Tubro CNC, a DOS based communication program with the
    interface. The interface is based on the UCN5804B drivers.
    I cut my first "sample" over the weekend. All lines, manually entered
    G-code. Whew! (I don't have a CNC program yet)
    Straight lines cut great. Max linear speed is about 10ipm. I'm cutting
    foam with a hot wire. The trouble come when I tried to cut a few arcs
    and circles. As the wire round each quatrant of a circle, the steppers
    slow down respectively (as they should)..... x slows as it reaches the
    90 & 270 degree quadrants.... y slows as it reaches the 0 & 360 degree
    quadrants. I hope this makes sense.
    The trouble is, as the steppers slow they stall and begin to vibrate.
    The program doesn't have a feedback from the steppers so there's no
    way for corrections to be made, and we get irregular arcs/circles.
    As far as I know the steppers are NEMA 42 running 5VDC. Linear
    movement is through a fine threaded rod. The drivers are set up for
    wave drive mode.
    Any ideas? I'm going to try two phase mode the first chance I get. As
    far as I know half step is at a loss of torque right?
    Thanks for you're time and any info. I'll check back frequently if
    there's any questions I can answer.
    5 volt DC seems a little low normaly you would run between 10 and 20 times the rated voltage of the stepper motor with current limit depending on the drive you are using.
    Do a search on the forum for stepper motor power supply.
    Andy
    Jan 2008
    38
    Talking low voltage
    Thanks for the information. The steppers are 5v, I assumed the supply was also. Maybe 5v at 10A or something. I guess I'll check the supply voltage with a meter and report back.
    Forgive the ignorance. I really did quite a bit of reading on the subject, but there comes a point where someone has to hold your hand or you do it the hard way.
    I considered building a bracket to hold a router for small wood working projects. Instead of a stepper, do you suppose using a solenoid and an adjustable stop for the z-axis would work? The wood I plan to cut is balsa, 1/4" or less. No oak or plastic. I haven't found another cnc works a z-axis this way..... maybe for good reason.
    Jan 2008
    38
    power supply voltage
    The supply voltage read 28.0VDC
    The voltage stayed constant when I jogged the machine, so I'm assuming the supply is keeping up just fine.
    Do I need to run more voltage? or should I borrow a meter and find the current delivered under a stalled condition? My meter won't do it.
    Would running the steppers in 2-phase mode do anything? The board is hardwired wave mode now. I'll have to some board mods to make the change. It'd been nice if it was a jumper or DIP switch.
    Jan 2008
    38
    I think I've answered my question
    Full step drive (two phases on)
    This is the usual method for full step driving the motor. Both phases are always on. The motor will have full rated torque.
    Wave drive
    In this drive method only a single phase is activated at a time. It has the same number of steps as the full step drive, but the motor will have significantly less than rated torque. It is rarely used.
  1. Stepper stall
    By ez-cnc.com in forum Stepper Motors / Drives
    Last Post: 12-24-2006, 04:10 AM
  2. servo stall shut off circuit
    By wcarrothers1 in forum DIY CNC Router Table Machines
    Last Post: 10-27-2006, 03:01 AM
  3. Need help with stepper stall
    By orbyog in forum Stepper Motors / Drives
    Last Post: 03-19-2006, 10:54 PM
  4. stall detection
    By mechanicer in forum CNC Machine Related Electronics
    Last Post: 01-23-2006, 10:08 AM
  5. peak vs stall torque
    By bboggess in forum Servo Motors / Drives
    Last Post: 08-25-2005, 06:56 PM
