588,397 active members*
4,825 visitors online*
Results 1 to 6 of 6
    Jan 2007
    56
    G85 for Boring Cycles?
    I was reading in my manaul today that I should use G85 for a canned boring cycle. I have a leadwell LTC-15 with a fanuc O-T controller. As I read on it said at the bottom of the hole there will be no spindle rotation. If Im not mistaken, shouldn't it still be spinning at the bottom of the hole? Besides that, I just wanted to make sure I was using the right code. Could I get an example of a quick canned boring cycle? Thanks a lot.
    Feb 2007
    464
    Of course it spins at the bottom.G85 has feed in and feed out with no dwell.G86 has feed in, spindle stop at the bottom and rapid out.
    Stefan Vendin
    2932
    G85 (feed in - feed out) and G89 (feed in - dwell - feed out) don't stop the spindle at the bottom of the hole. G86, G87, and G88 do. Here's one example:
    N03 G00 G40 G80 G91 G28 Z0 (SAFE START)
    T03 M06 (TOOL CHANGE)
    G54 G90 X1.0 Y1.0 S2000 M03 (POSITION X, Y & START SPINDLE)
    G43 Z0.1 H03 M08 (APPLY TOOL LENGTH COMP & COOLANT ON)
    G85 Z-1.0 R0.1 F10.0 (BORE HOLE 1" DEEP AT CURRENT X,Y)
    X2.0 Z-1.25 (BORE HOLE 1.25 DEEP AT X2.0)
    G80 M09 (COOLANT OFF)
    G91 G28 Z0 (ZERO RETURN Z)
    M01 (OP STOP)
    Remember, CNC programming is like skinning a cat. There's more than one way to do it, and your machine may not use this exact programming format.
    Nov 2006
    174
    O-T
    ....And he's running Fanuc OT control.
    Jan 2007
    56
    Excellent. Thanks for the help. I should be able to figure it out no problem now. If I run into anything Ill let you know. Thanks again.
    2932
    Oops, my bad. I should know better than to do ANYTHING before my first cup of coffee. Especially read, think or write. The lathe may not even have the canned cycles turned on. I'll do better...
  1. different peck cycles?
    By C5turbo in forum Fanuc
    Last Post: 11-06-2008, 12:03 PM
  2. canned cycles on 16t?
    By DocHod in forum Fanuc
    Last Post: 07-09-2007, 01:58 AM
  3. G90/G91 in canned cycles
    By alfalfa in forum CamSoft Products
    Last Post: 02-25-2007, 12:20 PM
  4. Mill cycles or Operations
    By camtd in forum EdgeCam
    Last Post: 10-20-2006, 06:38 AM
  5. canned cycles on Haas
    By GITRDUN in forum Haas Mills
    Last Post: 09-21-2006, 01:58 PM
