587,223 active members*
3,198 visitors online*
Page 1 of 2 12
Results 1 to 20 of 29
    Jan 2008
    92
    Another DIY Tumbler
    The one I am making will function the same as the one Unabiker made, I'm just going about it a little differently.
    I sourced the junk 100 pound gas cylinder from the local gas company. I just had to pay them 10 bucks for them to "devalve" it.
    The drive shaft will go thru the "gondola" under the tub. The flange mount bearing (2 ea) will mount up to the 4 hole bolt pattern.
    The support frame that the tub will sit on top of will be 2x2x.125 steel tube.
    I'll have the tubing Monday...stay tuned.
    Sep 2006
    113
    Smart thinking. I've got something similar in the works, although I fabricated my tub from scratch. I take it you're mounting the angle flanges on springs and putting counter weights on the drive shaft? If so, how do you plan on getting power to your drive shaft?
    May 2005
    1810
    Nice start!
    Scott
    Consistency is a good thing....unless you're consistently an idiot.
    Sep 2005
    86
    Looks good so far.
    I can't wait to see how it develops.
    Feb 2007
    45
    Very interesting, looks like it has great potential.
    Quality Type 2 Anodizing PM me For a quote!
    Examples of our work here! http://s74.photobucket.com/albums/i260/125Customs/
    May 2005
    2502
    Love these tumbler projects!
    BW
    Jan 2008
    92
    Getting there
    Quote Originally Posted by Jcar View Post
    Yep, the springs will go where the 1-2-3 blocks are. Power will be dilivered by V-belt.
    Jan 2008
    92
    Since I have no idea how much counter weight will be needed I wanted the set up to be as "adjustable" as possible. I bought two 1" ID x 2"OD x 3" couplers and stacked eight .120 steel plates onto them. I can add or remove plates as needed.
    The size of the counterweight and the # of plates was a total guess.
    Sep 2005
    86
    Good to see you are making progress.
    Some comments on what you've got so far-
    Those weights are going to create some powerful forces. Over time, these unbalanced forces will take it's toll on the shaft. You may want to think about adding another bearing to the end of your drive shaft. If that shaft is turning at 1000 rpm, the outside corner of your weight will be moving at about 50mph. You certainly don't need a hunk of metal moving through your shop at that sort of velocity. You might also want to start with less weight than you think you need and add plates as you go. The less weight spinning, the lower the potential for danger.
    With the motor located down low and close to the axle center line, the bearings in the motor are going to take some abuse with every upward movement of the tub. This abuse could be lessened by moving the motor up and further off of the axle center line.
    You might consider adding even larger gussets to your axle support or even a large plate across the back side of the support. By adding rigidity to the axle support structure, you will transfer more shaking force to the tub. Any place where flex is allowed will result in lost shaking force. It will could also result in welds cracking and metal prematurely fatiguing.
    Are you planning on springs all the way around or springs on one side and a pivot on the other?
    A large base like that could provide lots of room to weigh that baby down.
    Keep up the good work.
    Jan 2008
    92
    Mcmaster-Carr never ceases to amaze me. The motor they sent had no ID label on it, no markings what-so-ever. So I call, 1.5 days goes by and I don't hear back from them.
    So today the FedEx truck brings me another motor...with a ID label on it. Nowhere does it say to send the 1st one back :devious:
    Jan 2008
    92
    I took Unabikers suggestion and cut the counterweight in half. Four .120 thk plates on each side.
    The gondola mat thickness is .120. I was supposed to use .134 but grabbed the wrong stuff. I'm thinking .187 would probably be best. I gusseted and welded 'er up good, we'll just have to see how she holds up.
    I am using four 2.0 Dia.x 3"x .192 wire springs to suspend the tub.
    I put 60 lbs of water in the tub and fired 'er up for a few seconds. I may have more amplitude than I need but I'll have to wait 'till I get 150 lbs(?) of media in there and see what happens.
    Jan 2008
    92
    Feb 2007
    45
    Quote Originally Posted by Ted383 View Post
    Mcmaster can be very weird. Friend of mine ordered about 13-14 small packs of orings. He ended up getting an oversized boxes for each size oring he ordered. He payed like 5 bucks for shipping all together.
    Jan 2008
    92
    Well this is what 150lbs of media and 5gals of compound look like. The rocks are synthetic plastic triangles, 1.25x.625x.875 with a "general purpose" classification. The compound is made to be used with plastic media, one oz per gallon.
    I paid $1.04 per pound for the rocks and $41 for 5 gal of compound. Total with shipping was $274.
    I got it all here... http://www.vibratoryfinishing.com/
    Oh and BTW. Mcarr sent a call ticket to pick up the other motor
    Sep 2005
    86
    What sort of parts are you going to be running through your shaker?
    I've always used the green rocks which are a step finer than the pink. I am eager to see how the pink ones work. I've also got a jug of that compound. It seemed to really slow my process down, so I just run straight water.
    Feb 2007
    45
    Anyone have any experience with the Preplate Light green/white plastic media? Im looking for something that will give the smoothest preplate finish prior to polishing/burnishing.
    Jan 2008
    92
    Unabiker
    I'll be running .060-.125 thk alum sheet metal parts in the tumbler. Very similar to what you do execpt all my stuff gets powder coat. Surface finish is not an issue so fast deburr and paint prep are all I looking for. According to
    http://www.vibratoryfinishing.com the green stuff is for "extremely fine finishes".
    I will be running the first batch thru the machine today or tomorrow. We'll see how it goes. I'll try it W/O the compound for a while then add some and see how it effects the action.
    Jan 2008
    92
    I bought two plastic barrels for 8 bucks ea. One was .250 thk and the other .170. I used the thinner of the two to make the liner. 4 pop rivets and the drain are all that is holding it in place. If I do line the ends of the tub it will be later.
    Jan 2008
    92
    As I mentioned earlier, the tub had way too much movement the way it was so I trimmed 11.5 ozs off the counter weights (yeah I know it's a odd ball shape, but it just ended up that way).
    It made all the difference in the world but the 800 RPM that the axle was turning was not enough. I installed a larger drive pulley to bring it up to about 1000 RPM.
    Now I'm ready to run a load of parts thru it.
    May 2005
    1810
    Very cool work. Nice and clean!
    Scott
Page 1 of 2 12
  1. Which type of tumbler is better for Al?
    By bob1112 in forum Mass finishing equipment/media/strategies
    Last Post: 04-27-2011, 05:10 PM
  2. DIY Vibratory Tumbler
    By mxtras in forum Mass finishing equipment/media/strategies
    Last Post: 10-17-2007, 06:53 AM
  3. Vibratory or tumbler for slag?
    By BallisticFab in forum Mass finishing equipment/media/strategies
    Last Post: 03-05-2007, 10:14 PM
  4. Vibratory tumbler comparison
    By mtechserv in forum Mass finishing equipment/media/strategies
    Last Post: 02-10-2007, 03:57 PM
  5. Tumbler vs. Hand finish/polish
    By DAB_Design in forum MetalWork Discussion
    Last Post: 07-08-2004, 11:03 AM
