588,535 active members*
7,697 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > How can I mount a chuck in my mill spindle?
Results 1 to 7 of 7
    Mar 2004
    576
    The mill spindle is R8, and I want to mount a 3" or 4" chuck in it. I can't find any type of mount for a chuck, but I'm not sure if I just don't know the correct keywords for whatever I need for this?
    My other thought was to machine a mount plate that's essentially a disk with a 3/4" shaft on it, and the shaft would go in a 3/4" R8 collet in the mill spindle. The chuck would then get bolted to the disk part. But if I can find a ready-made solution I'd prefer that route.
    Ideas, thoughts, pointers?
    Thanks,
    -Neil.
    Jul 2005
    12177
    Your plate on a 3/4" shank idea is probably close to the best; the only change that might make it more rigid is to use a face mill holder and make a plate to fit this. There have been a few threads about putting a chuck on a mill spindle and I don't think anyone found a ready made solution.
    Here is a link that takes you to one thread, these are dealing with larger size CNC mills:
    http://www.cnczone.com/forums/showthread.php?t=51075
    And here is one I did for fun which shows what is possible:
    http://www.cnczone.com/forums/showth...398#post406398
    Mar 2006
    489
    There's a guy on e-bay selling 3" and 4", 3 jaw chucks that have an r8 taper. Price was pretty cheap too.
    http://cgi.ebay.com/BRIDGEPORT-R8-SH...QQcmdZViewItem
    Paul
    Jun 2004
    6618
    That would be nice for a fourth axis using a spare R-8 spindle head from an X2. Limited by no through hole though. It does spark some ideas.
    Lee
    May 2007
    781
    If you need a thru hole look at the 5C collet stuff.
    Mar 2004
    576
    Quote Originally Posted by fatal-exception View Post
    Paul
    Dibs!!!
    Mar 2004
    576
    So I picked up one of these from an Ebay seller for $40 -- a 4" chuck with an R8 mount. I wasn't too thrilled by the seller, but the product is decent. I did not slip smoothly into the R8 spindle on my mill, but it wasn't too bad -- I just had to pull it up with the drawbar. But the main purpose was met -- to do some CNC turning on my mill. Pretty neat! I should measure with the dial indicator to see how concentric it is though.
    Thanks,
    -Neil.
  1. Sweo spindle drive? new mill dead spindle
    By Shizzlemah in forum Fadal
    Last Post: 12-18-2008, 06:11 PM
  2. Spindle Chuck Questions
    By SPEEDRE in forum DIY CNC Router Table Machines
    Last Post: 01-19-2008, 07:28 AM
  3. Tool Mount For Jacobs Taper 3 mount
    By pzzamakr1980 in forum Tormach Personal CNC Mill
    Last Post: 03-29-2007, 08:31 PM
  4. How do I remove a kwik chuck/spindle
    By Andyh in forum Bridgeport / Hardinge Mills
    Last Post: 08-14-2005, 06:28 PM
  5. manual mill Z axis conversion mount
    By Bryscnc in forum Bridgeport / Hardinge Mills
    Last Post: 04-04-2005, 11:10 PM
