588,136 active members*
6,316 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Feed rate? Slot cutting with 0.031" endmills?
Results 1 to 6 of 6
    Nov 2007
    1702
    I really should post this to one of the general forums but there are enough Haas guys here that I'm hoping for directly applicable opinions.
    I am about to make some parts which need slots cut into 6061. They are 0.031" wide and 0.021" deep. A slitting saw is not an option since the paths will eventually have curves in them (if this prototype succeeds).
    I purchased 1/32" flat and ball carbide endmills (to experiment with each). I'm trying to calculate safe feeds.
    Starting with a 0.25" endmill, I could safely assume 0.002" chip load. Scaling the diameter down to 0.031", the proportional chip load would be 0.00025. At 10K RPM, that would be 5 IPM--fully buried. By the 'normal' calculations, I'd figure 0.5D (0.016 deep) at 5 IPM
    5 IPM just sounds too fast to me for such a small, fragile endmill. Can I use this method of 'scaling' to estimate safe feeds? Time isn't that critical but I don't want to spend days machining the parts either. If I don't scrap anything, I have about 30 inches of aluminum to cut these grooves into (in as many passes as it takes).
    Any suggestions?
    Greg
    Dec 2006
    447
    After soliciting opinions on this forum I ran a .0625 carbide 3 flute EM at 6000 rpm and 7 IPM for two days, over 300 feet on the same EM. This was full width and .045 deep. I don't think you are that far out of the park with 5 IPM.
    Vern
    Oct 2006
    48
    Smile slot milling
    Hi Greg--- I don't have a machining center, I have a cnc bed mill the max. speed is 4,300rpm. I machine 6061 with .031 2 flute carbide center cutting end mill @ around 4,000rpm-2. ipm-.020doc it's pretty slow I know.
    Feb 2008
    183
    I don't think your off on those numbers.I did some small slots like that in golf club heads years ago,and they were about half what your looking at,and they were in steel.Hated the part,but loved the money.
    Nov 2007
    479
    Quote Originally Posted by Donkey Hotey View Post
    Any suggestions?
    That should work just fine. I would even use those speeds and feeds in stainless.
    Aug 2005
    235
    That looks to be good. I just finished running some parts with 0.031" endmills to cut small pockets in O-6 tool steel . Used 0.02 DOC at 2 IPM 6000RPM. You should be just fine at 5 IPM and 10000 RPM in aluminum. Use lots of coolant.
  1. High feed endmills "Feedmills"
    By MDLang in forum MetalWork Discussion
    Last Post: 05-25-2013, 02:32 PM
  2. Feed rate Ovverride also Increases rapid rate.
    By Korellibopper in forum Machines running Mach Software
    Last Post: 01-31-2008, 12:37 AM
  3. Feed Rate and Spindle Rate for this cut?
    By DroopyPawn in forum MetalWork Discussion
    Last Post: 11-22-2007, 06:12 AM
  4. "tool slot number too large" code
    By dave6 in forum Mach Mill
    Last Post: 10-10-2006, 11:57 PM
  5. How can I up my feed rate ?
    By ynneb in forum DIY CNC Router Table Machines
    Last Post: 07-13-2004, 03:40 AM
