Originally Posted by
metalworkz
Hi Mike,
Did you save the file after changing the scale? Look at the X or Y coordinate reading( mouse over the end of the part etc) and take note of the size. Then change the scale and check it again, but you may have to save the file(give it another name) before it will print diferently. Not sure but that's my guess.
Also maybe changing the sacle is not changing the print image size, so try looking at the actual dimensions or coordinate readings on the drawing after changing the scale.
Regards,
