588,205 active members*
4,119 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Help cuttting from the back side??
Page 3 of 4 1234
Results 41 to 60 of 79
  1. #41
    Nov 2005
    48
    Previous MCX
    Not that I'm desperate....
    James
    Attached Files Attached Files
  2. #42
    Apr 2003
    3578
    Review my file. sorry about the delay i had vendors and PE's (Project eng's) coming to me and quotes to do.
    Cadcam
    Software and hardware sales, contract Programming and Consultant , Cad-Cam Instructor .
  3. #43
    Nov 2005
    48
    Quote Originally Posted by cadcam View Post
    Ok that is perfect, how come it works on your on e and not mine???
    ^o)
    James
  4. #44
    Jay,
    Can you describe what was wrong and how you fixed it? Thanks.
  5. #45
    Nov 2005
    48
    is CADCAMs Name Jay?
  6. #46
    Nov 2005
    48
    Ok it didn't take me long, but it is a good thing, I broke the model???
    It doesn't work now, but it does now narrow it down to a setting actually on my computer here?
    What could it be?
    James
    Attached Thumbnails Attached Thumbnails Tool plane must be set to TOP or off in entry MKii.jpg
  7. #47
    Nov 2005
    48
    Quote Originally Posted by Skin View Post
    What could it be?
    James
    See if any of you can make any sense of this?
    Ohh and I did like the little touch of leaving tabs on the bottom too, it was noticed
    james
  8. #48
    No it's Jayson.
  9. #49
    Nov 2005
    48
    Quote Originally Posted by Mike Stevenson View Post
    Yes it is.
    Can he come back please now??
    Jay H-E-L-P !!!
    J
  10. #50
    Apr 2003
    3578
    I will be back am busy this moment.
    Cadcam
  11. #51
    Nov 2005
    48
    Ok
    No pressure or anythign like that at the moment, I just wanted to know you were okay
    I'll just get back to worrying quietly now
    J
  12. #52
    Apr 2003
    3578
    Most call me Jay as mike has stated my full name is Jayson.
    Cadcam
  13. #53
    Nov 2005
    48
    Jay my name is James, and its a pleasure to make your acquaintance.
    Sorry for all the haassle on here and the barrage of questions, I've just been staring at this now for days knowing it should really work, and I should be cutting metal, but 'Computer says NO' and I am running out fo logical buttons to press :S
    J
  14. #54
    James,
    Don't let your machine sit over this. Do what I said earlier and translate/rotate the part to the top view so you can keep your spindle turning.
  15. #55
    Apr 2003
    3578
    So I broght the file in and wants go in a different plane ,interesting.But if I force a regen on that op it all good.
    What machine def are you using.
    Cadcam
  16. #56
    Nov 2005
    48
    its twenty to midnight here, I'll let it chill till morning, it has turned into a principle thing, the prgs are written in the three part breakdown, but I don't like to give up on these things, especially now that I've seen it run properly on THIS screen, and then imedialtly break too????
    But thanks, and I'll be doign what I can soon.
    J
  17. #57
    Nov 2005
    48
    I'm using a standard 3 Axis Vertical Milling Machine in mm's just standard out fo the stock options here, I haven't started making one that is based on ours yet?
    J
  18. #58
    I am the same way I go nuts if I can't figure something like this out. good night mate.
  19. #59
    Nov 2005
    48
    Nooo the night is far from over here, I love a time shift away from you in the states, so I'll just sit and be patient for tonight, tomorrow the most important things I have to do are write CNC programs for mill and go down to the test track and try out our new bike
    but the longer I don't have this running properly the longer we wait to start rewriting our progs, so at this point I'd like to start things out properly, instead of having to have three MCX files and three NC codes and 3 SolidWorks parts for every one part we want to cut, at this point whilst I have the luxuary of digging my heals in, I'd like to know I can rationalise what I'm doing here properly
    J
  20. #60
    Apr 2003
    3578
    Guys I am the same way I will play for hours if need be to figure it out.I am off to teach class. talk to you in the AM.
    Cadcam
Page 3 of 4 1234
  1. side mount tool changer-I take back what I said about
    By 1ctoolfool in forum Haas Mills
    Last Post: 03-12-2010, 05:04 PM
  2. Z-axis - mounting rails on spindle side, rather than tower side
    By guru_florida in forum Linear and Rotary Motion
    Last Post: 02-01-2008, 01:54 AM
  3. cuttting head?
    By skaha in forum DIY CNC Router Table Machines
    Last Post: 10-18-2006, 04:59 AM
  4. mounting linear rails side by side
    By 50062040 in forum Linear and Rotary Motion
    Last Post: 10-24-2005, 01:49 PM
  5. take more off the top or side?
    By corpse in forum MetalWork Discussion
    Last Post: 08-04-2005, 09:43 PM
