587,997 active members*
1,916 visitors online*
Results 1 to 18 of 18
    Apr 2007
    641
    need help! with drivers
    I have installed some nema 34 1160 oz motors from keling,(X and Y) I can jog them a little and then the stop in the DRO (MACH) start to blink. I have set them bipolar and set the current to 6.4 .
    For the Z axis I have a nema 24 595 oz motor, it doesn´t start but gets warm.
    >Dont know what to do, I have changed acceleration and velocity , but nothing changes.
    Aug 2005
    828
    Does it say soft limit activated? Is your soft limit buttom turned off?
    Dennis
    Apr 2007
    641
    It says: external stop requested when it starts to blink.
    Aug 2005
    828
    Do you have the estop connected? If no, then change the settings in Config (top left corner) then Port and Pins then Input Signals tab and scroll to Estop and disable it for now.
    Dennis
    Apr 2007
    641
    Yes I have it in low, then i´ll disable tomorrow and tell what happens.
    Thanks for help
    Luis
    Apr 2007
    641
    I ´ve disbled the estop, had to put a 0 in the port, now the machine works, but have no Estop. I have checked the stopsbut everything is ok, tomorrow i´ll change the pin in the board, any other idea???
    Luis
    Apr 2007
    641
    I have some noise and vibration problem with the 1160 oz motors. I set the steps per at 60 as result of the fine tunning to get the same travel as the dro. My resolution is 1/8, gear and rack 20 pitch , 20 teeth, pulleys 3:1and have set the motors at 6.4 v parallel con. Am, I rigth?
    Aug 2005
    828
    You have a power supply of 6.4v to the motor drives? or do you mean Amps?
    Do yo have micro-stepping drives? What brand drives?
    Dennis
    Apr 2007
    641
    I get it from Keling , he already told me 6.4 v is ok in the driver (current settings)
    what I´m not really sure is about the steps per.
    Scott from MACH told me to use the setting for steps in the mach dro- settings.
    I have changed the velocity and accel but noise continues..
    Aug 2005
    828
    What do you have the micro step setting on the drive?
    What drive model do you have:?
    http://www.kelinginc.net/KLDriver.html
    Dennis
    Apr 2007
    641
    driver 8078, set at 1/8 (1600 steps)
    Aug 2005
    828
    This will be your steps per inch:
    1527.88745368219522338128
    1,600 x 3 / pi= 1527.8874536821952233812841283761
    your 20 tooth gear has a pitch diameter of 1 so it will go (pi) distance in one revolution.
    Sorry I missed the 1/8 in your last post.
    Dennis
    Apr 2007
    641
    I have it at 62 ! And if I input 30mm in the dro the axis travel 30mm , John from kellling told me the same , that i have it wrong:
    But in the settings tab (MAch dro) the button for SET STEPS PER< GIVES ME THE SAME 62.
    Then... could be any other thing setting wrong ?
    Apr 2007
    641
    Scott from Mach support told me that 1500 steps per sound like inches, and also told me that 62 is more close to the mm as I ´m working with.
    The machine is giving the measures ok, only problem left is the noise an vibration,
    Apr 2007
    641
    Now I have another problem, I connected the plasma direct to the # 1 output pin of the board with the 5 volt relay, it starts firing but for a few seconds 1 or 2 inches and then stops and also stop the machine. I checked firing the plasma manually outside the machine independet from the board and it fires normally, looks like the 5 v relay opens the contact or something from the software...? any clues?
    Apr 2007
    641
    I have some noise problem ,
    The plasma works ok if I work it by hand. But if I work from the
    machine it stops after 10- 15 secs. In the DRO the stop is triggered
    and it says limit triggered or stops triggered. So, I disconected the
    plasma from the machine and triggered manually, the machine stops,but
    the plasma dont, So, I disconnect limits and stops and triggered the
    plasma from output 1 and again the machine stops after 10 secs of
    cutting.,
    I have the motors connected with shielded cable , but stops and limits
    with regular cable.
    All the grounding with cooper rods 4 ft. one fro the plasma the other
    for the table. Pc and electronics from the building ground.
    Thanks in advance for the help
    Luis
    Apr 2007
    641
    Replaced board
    I had to replace the C10 board (cnc4pc) because someone welded over the cncplasma table and blow it.
    I have connection with the limits and stops but the motors don´t spin, I have changed the driver and tried other motor but nothing works. Checked the serial cable ,pins , etc any idea?
    Luis
    Apr 2007
    641
    Scott form MAch helped me with the problem , the motors did not spin, then in motor tuning i rised the step and dir pulses to 16 and now the machine is working.
  1. Best DIY Drivers
    By dshowalt in forum Polls
    Last Post: 11-06-2007, 04:30 PM
  2. Can i use these drivers
    By erase42 in forum Servo Motors / Drives
    Last Post: 01-25-2007, 04:35 AM
  3. old drivers
    By erase42 in forum Xylotex
    Last Post: 10-23-2006, 11:08 AM
  4. Has anyone used these drivers
    By xlleisure in forum Stepper Motors / Drives
    Last Post: 08-23-2005, 01:27 PM
  5. Drivers - Help!!!
    By johnm99 in forum Stepper Motors / Drives
    Last Post: 08-10-2005, 08:33 PM
