588,695 active members*
6,816 visitors online*
Thread: alarm 078
Page 1 of 2 12
Results 1 to 20 of 25
    Apr 2005
    18
    Wink alarm 078
    hi all ,, my CNC machine stop transfer data , it shows alarm P/S 078
    what to do ? I am new with Fanuc
    Sep 2005
    767
    Are you sure it's alarm 078? An alarm 087 would be an RS232 buffer overflow condition.
    Dec 2003
    24222
    The P/S alarms are usually program format alarms I show this in the alarm list
    P/S 078 NUMBER NOT FOUND A program number or a sequence number which was specified by address
    P in the block which includes an M98, M99, M65 or G66 was not
    found. The sequence number specified by a GOTO statement was not
    found. An attempt was made to call a program being edited
    Al.
    Albert E.
    Apr 2005
    18
    yes as you said Dan Fritz it is alarm 087
    RS232 buffer overflow condition. ,what to do please ???
    It drive me crazy ...
    2932
    PS087 alarms occur when the PC sends 10 characters after the CNC has told it to pause.
    Are you using a laptop with USB to Serial adapter? I've had handshake problems with these in the past. I would recommend a PCMCIA Serial adapter if you have to use a laptop.
    You might also try turning off the FIFO buffers in Windows Control Panel - System - Hardware - Device Manager - Ports - Port Settings - Advanced. Move the sliders all the way to the left, then check the "Do not use FIFO buffers." Okay everything then reboot the computer.
    Dec 2003
    24222
    ..And of course, your DNC s/w should be set for XON/XOFF software handshake.
    Al.
    Albert E.
    Apr 2005
    18
    Quote Originally Posted by dcoupar View Post
    No just PC & not USP
    I turned off buffers in windows control panel & did the slide to the left and restart ... still the same problem ... I am disappointed please guys what to do
    I have this alarm 087
    530 overtravel +z
    never wanted to be different, I just wanted to be me
    Dec 2003
    24222
    What software are you using to communicate with?
    Are you using a 3 wire cable with the Handshake jumpered out?
    What is the model of control?
    Al.
    Albert E.
    Apr 2005
    18
    Unhappy ???????????
    I send in the attachment picture : SDNC comunication software that I use .
    Are you using a 3 wire cable with the Handshake jumpered out ?
    I dont know what does it mean ? I am new to this , but it was sending without problem ( i mean the cable is good )
    Dec 2003
    24222
    You have not indicated what Fanuc model this is, the alarm codes can vary, if it was working on the DNC and now you have o87 alarm, it could mean there is a problem with the I/O port.
    Al.
    Albert E.
    Apr 2005
    18
    Fanuc series O-M
    it was working probably , we were doing cavity for blow mold & we did the rough program we did it in two ways buffer and save butthe finish program was too long to save , that is why we tried to do buffer !!
    Attached Thumbnails Attached Thumbnails DSC00-1.jpg   DSC00-1 (1).jpg   DSC00-1 (2).jpg
    Dec 2003
    24222
    Well here is the P/S alarm right out of the manual.
    '087 BUFFER OVERFLOW When entering data in the memory by using Reader / Puncher interface,
    though the read terminate command is specified, input is not interrupted
    after 10 characters read. I/O unit or P.C.B. is defective.'
    It looks like the handshake is not on, if the external PC does not stop or sends more than 10 characters after the DC3 stop code has been sent from the CNC, then 087 alarm will occur.
    What transmission baud rate are you using?
    Al.
    Albert E.
    Apr 2005
    18
    Red face
    we use this :
    bit per second 9600
    data bit 7
    parity even
    stop bit 2
    that what I understood from the reply
    Apr 2005
    18
    Red face
    we use :
    pit per second : 9600
    Data bit : 7
    Parity : even
    stop bit : 2
    this what I understood from your reply ... sorry I am CAD/CAM engineer
    we bought the USED machine ready to receive from Mastercam
    Dec 2003
    24222
    You can try 4800 or 2400 baud, you have to change it both ends, make sure the PC software is set for software handshake, if you want the Fanuc RS232 manual, you can send me a email address via P.M.
    Al.
    Albert E.
    Apr 2005
    18
    I can change it on the PC but I have no idea how to get it on the CNC , i dont know how to do it ? where ?
    my DNC software is so simple there is no option or setting to change ..
    ya please I need it my E-mail [email protected]
    Al_The_Man I appreciate all your Efforts , help and fast reply
    and I am thankful for all members for helping .
    Dec 2003
    24222
    Quote Originally Posted by H_U_S_S_A_M View Post
    I would be very surprised if you have communication software that does not allow option to change settings?
    It should be in 'Configure' or 'Setup' or similar worded menu.
    I have sent the manual for the CNC side.
    Al.
    Albert E.
    Apr 2005
    18
    السلام عليكم
    thank you for your helping ,
    but I still want to solve my problem , I need little help , yesterday I send you the my CNC photo , can you tell me in steps how to reach bound rate menu 9600 on the CNC to change it ? in the main screen what to do ?
    can I find the guide in the manual ??
    Aug 2005
    149
    Try this software http://www.cadem.com/ it's free...I had problems with sdnc...use this software an you can adjust the 10 characters to help eliminate this alarm.
    Dec 2003
    24222
    The two parameters that deal with baud rate are 0552 or 0553 depending on what port you are using, you have to set the PWE bit on the setting screen to 1. to change the parameter, change it back to zero when done.
    page 33 shows the baud rate numbers.
    Al.
    Albert E.
Page 1 of 2 12
  1. Replies: 2
    Last Post: 09-10-2018, 09:21 PM
  2. Replies: 6
    Last Post: 04-29-2011, 11:20 PM
  3. VFE - ALARM# 117
    By j-radkemachine in forum Haas Mills
    Last Post: 12-06-2007, 11:57 PM
  4. Alarm out?
    By 12jbowler in forum DNC Problems and Solutions
    Last Post: 03-01-2007, 02:04 AM
  5. Alarm 367?!
    By jprobst in forum Haas Mills
    Last Post: 02-01-2007, 08:23 PM
