587,751 active members*
2,896 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > How do you counterbore?
View Poll Results: How do you countercore with cnc ?
Voters
34. You may not vote on this poll
  • plunge center then interprolate
    11 32.35%
  • plunge and spiral xy
    5 14.71%
  • spiral with z ramp (helix)
    17 50.00%
  • other
    1 2.94%
Results 1 to 6 of 6
    May 2005
    1662
    Counterbores for smallish SHCS's, half inch SHCS and less.
    Assumes a tool isn't available to simply plunge to correct size.
    Pic of option #1. It's a canned cycle on most controls probably. The line represents center of tool path.
    Edit/ Assume the bolt hole has been drilled before counterboring
    Feb 2007
    592
    Wink C-bore code
    Yeah thats how I do it.
    I use a G13 when available, (G3xx on Okuma, I forget the exact code)
    From the look of your screen shot I should hurry up and port my G13 macro ( For FANUC's which DON"T support G13 ) to an EMC2 Osubcode.
    May 2005
    1662
    Quote Originally Posted by skullworks View Post
    Caught me! Should have cropped that screenshot
    It would be great if the emc interpretor had a canned cycle for this routine. If you have a macro, post it somewhere. Sharing is caring
    There is an ulterior motive to this poll. I've been writing a few gcode generators for users of various experience levels. The c'bore module already does options 1 & 2. Been debating whether to include option #3. The fear is inexperienced users may get into a world of hurt with extreme ramp angles. Maybe #3 should be included with a warning attached.
    For those who chose option #3; what ramp angles are you using? Assume the types of EM's generally used by hobbiests.
    Feb 2007
    592
    Arrow
    Quote Originally Posted by cyclestart View Post
    I was brought up in the trade with the understanding that the whole spiral ramp method was a psydo kludge, a way to skip drilling and get a non-centercutting insert type endmill to depth. It takes longer than a center plunge, loads all 3 axis, and doesen't cut as freely. Hitler lost the war fighting on 2 fronts, the same applies to endmilling on a less than rigid hobby type machine.
    Also of note: "Economical" HSS 4 flute EM's, even when of the "center cutting" type don't have great chip ejection even with flood coolant and tend to load up.
    As to ramp angle my rule of thumb has been to use 5% of the cutter radius as the max infeed per 360°. But again, spiral ramping is not one of my preferred methods.
    Maybe let your macro tool calc the ramp & number of helical passes to get to the requested depth. Then if the user so decides they can edit the final code.
    May 2005
    1662
    Yep, the flexi-flier factor can't be ignored. The software must work with desktop size machines.
    My thoughts were to allow the user to enter a ramp angle. As the tool size approachs the target size, any other method could result in high ramp angles. Hmm, the clogging ... looks like some test runs will be needed.
    Back in the day I used option #1, sometimes option #2 on Milltronics. Judging by the poll this might be old school thinking. Then again I am old. Another birthday today as a reminder
    Jul 2006
    155
    I helix almost all my holes that I can't just plunge to size almost all the time, with great results! as for ramp angle I like to use the ramp depth method instead and just pick the pitch the helix, I think that it is a lot easier to think of how much the cutter is actually cutting that way.
    "you don't even need cnc if your handy with a torch"
  1. Counterbore/drill combo
    By ossito in forum CNC Tooling
    Last Post: 08-07-2006, 06:58 PM
