Got the electronics, bearings, and rails... going to begin construction soon.
55 inch 20mm pillow block rails. (Same length as foos)
15 inch THK rails for the Z.
34 inch Thompson 1" for the Y. (Same width as foos)
Gecko 203Vs
CNC4PC 11G
400 VAC
50VDC
8Amp
PSU
KL23H276-30-8B Stepper Motors...
http://www.kelinginc.net/KL23H286-20-08B.pdf
Got the electronics working... so figured it is time to start.
Planning to keep the Foos theme (Foos guys for dampers and table painted as soccer field)
The foos table has a weak tabletop. Going to replace with a buildup top.
Sides of the foostable must be cut to allow for the gantry slide.
Any thoughts?
