587,997 active members*
2,207 visitors online*
Results 1 to 11 of 11
    Mar 2008
    5
    Hard Part turning
    Hello guys
    We are thinking to start Hard part turnning on PUMA 400
    Has anybody tried earlier?
    Can anybody give me more info. about hard turning?
    May 2007
    1003
    One word. Ceramics.
    Jan 2007
    5
    Kyon work well.
    Fiber imbedded ceramics if you need high strength.
    May 2007
    1003
    Start out with shallow DOCs and slower feedrates...around F.005 for ceramics. Either run dry or make sure there is plenty of coolant on the insert. We run dry.
    Mar 2008
    5
    Hard turning
    Thank you for your valuable info.
    I am happy to tell you that we have succesfully turned components of 62 HRC hardness within 0.006-0.008 mm tolerance range.
    But there is a small problem we are facing.
    Microstructure looks slightly reddish.
    Any suggestions?
    May 2007
    1003
    Sorry. Can't help you with that. Never noticed anything like that with the few parts we have run. Only job we run on a regular basis is from 52100. Just out of curiosity, what material are you running? Maybe someone else will have an answer for you.
    Mar 2008
    5
    Hard turning
    Material is 16MnCr5
    May 2007
    1003
    LOL. Couldn't guess off the top of my head what material those numbers relate to. Not at work, so I couldn't check them against materials I am familiar with.
    Mar 2008
    5
    16MnCr5 means Carbon steel with 0.16 % carbon,5 % mangnese and 5 % cromium.It's designated according to Beuro Indian Standards(BIS).
    May 2007
    1003
    That much I could figure out. Still doesn't help me. What does it equate to in America? 4340, 4140, 1215, BG42, 52100, 8620, 1117, 4350, 1018, O1, D2, etc., etc. Sorry, but I forgot to try and look it up today. Had a day off yesterday to spend with my grandsons. Maybe I'll remember tomorrow.
    Mar 2008
    19
    Wink 16-5 Niquel based materials
    This are very hard SS steels, so machine slowly unless there are a lot of steps or holes, start with high speeds and decrease as much to avoid overheating but not that much that you early break the Inserts.
    DO NOT USE CARBIDE INSERTS, LOOK FOR COBALT OR CERAMIC, I would advise to use Toshiba, You may use high feeds but Ar or deepness should be shallow as to produce hairly like continuous wire burr. Watch out for the angle of insert, use 1mm radius or less.
    Ceramic inserts do not need coolant, thermal shock destroys them, cool with cool air.
    Santiago Yamin,
    Mexican Aerospace Components.
  1. How hard would it be to machine this part?
    By kentrob11 in forum MetalWork Discussion
    Last Post: 03-28-2008, 07:06 PM
  2. Part holding and milling 3D part on 2.5D Mill?
    By john_t_h in forum MetalWork Discussion
    Last Post: 03-15-2008, 12:35 PM
  3. Hard turning
    By Steve@Reliance in forum Material Machining Solutions
    Last Post: 07-31-2006, 06:33 AM
  4. First hard part, Help!!
    By fastolds in forum GibbsCAM
    Last Post: 06-08-2006, 08:37 PM
  5. hard turning carbide
    By bonz in forum MetalWork Discussion
    Last Post: 01-21-2005, 06:24 PM
